Old 01-23-2019, 02:12 PM   #1
1LEASYE
Drives: 2018 Camaro 1SS 1LE
Track Day Insurance/Tools
Which companies provide the best track day insurance and is there a long turn around time as far as getting a quote from any of these insurances companies?
Also, besides a tire pressure gauge, what are generally the tools most of you all carry to the track? I'll be driving just my SS 1LE to and from my track day down in March at Road Atlanta so the less items that I don't need to carry the better.
2018 Camaro 1SS 1LE
1LEASYE is offline   Reply With Quote
Old 01-23-2019, 02:52 PM   #2
Laststandard
Drives: 2018 1SS 1LE
Tire pressure gauge, torque wrench with extension and lug nut socket, extra quart of oil, paper towels, windshield cleaner and a rag.. that's about it.
I haven't done track insurance yet as I've only been on a small, local track.
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 01-23-2019, 03:13 PM   #3
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I use RLI / Hagerty track insurance I purchase it a week before the event but I could probably push it even closer to the event.
Really if you have the onboard electric air pump/ tire gauge you are good to go. You could just check the wheel nut torque the night before and call it good.
But if you really want to prepare for emergencies you can bring as much gear as you like. I was getting low on pad material when I made my 2nd Road Atlanta event so I brought a small cardboard box with new front and rear pads and a the tools required to change pads.
I also brought a spare quart of oil but I never needed it.
Old 01-23-2019, 03:31 PM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
speedventures has a track cheklist on site its pretty handy!
http://www.speedventures.com/
kropscamaro16 is online now   Reply With Quote
Old 01-23-2019, 03:44 PM   #5
JD_
JD_'s Avatar
Drives: 2018 2SS 1LE in Nightfall Gray
For insurance, usually RLI.
As for tools, here is my list:
plastic bin w/lid
torque wrench, extension and socket
breaker bar
multi-tool
tire gauge
microfiber cloth
paper towels
window cleaner
painter's tape
track tape to protect paint and tape down magnetic numbers (I like TrackArmour 6'' x 100')
plastic ziploc bags for small items (valve stem caps are the things I lose most)
Not tools, but good to bring if you have room:
folding chair
cooler and bottled water
JD
JD_ is offline   Reply With Quote
Old 01-23-2019, 03:49 PM   #6
Dave-ROR
Drives: A few
RLI/Hagerty or Lockton. RLI is cheaper but I don't know anyone who's had to actually use the insurance. I do know people who have used Lockton and had no issues with payouts/etc.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
Old 01-23-2019, 04:38 PM   #7
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Duct tape and zip ties.
'18 1SS 1LE Black, PDR
Old 01-23-2019, 05:53 PM   #8
kjchristopher
Drives: 911SC
I use Hagerty
kjchristopher is offline   Reply With Quote
Old 01-23-2019, 06:17 PM   #9
Rodan
Rodan's Avatar
Drives: 2018 ZL1 coupe
RLI here as well. Hagarty uses RLI, it was a little cheaper to go direct to the source. Online quote and purchase... easy, peasy.
As far as tools/supplies, it all depends on how serious you are. If you're driving to/from and running on your street tires, a tire pressure gauge about covers it. You may need to air up after leaving the track and the tires cool down, but it's unlikely you're going to need fluids with a newer car. Wheels should be properly torqued before leaving.
From there, you can go as nuts as you want, only limited by available space. Most people don't go much further than a jack, torque wrench, and air tank if they're switching to track tires. An electric impact wrench is very handy. Once you get past track wheels/tires, your experience and your particular setup will drive your tool/supply needs.
Don't forget a chair, big hat, sunscreen, snacks and fluids!
Rodan is offline   Reply With Quote
Old 01-23-2019, 06:36 PM   #10
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Flush your brake fluid with dot 4. Bring a lug wrench and ck in am and at lunch. Use recommended oil. Air pressure gauge. Start at about 30 cold..be careful on g3s in cold temps. You can wait till day b4 for track insurance in case of weather or plans change.
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 01-24-2019, 07:28 AM   #11
nasbagoat
Drives: 17 SW 1LE
I use On Track Insurance, usually buy a few events at a time to get some extra discount.
nasbagoat is offline   Reply With Quote
Old 01-24-2019, 08:08 AM   #12
Gasoline_Farts
Drives: 19 SS 1LE
How much does insurance typically cost for a weekend?
Gasoline_Farts is offline   Reply With Quote
Old 01-24-2019, 11:05 AM   #13
pbsinternet1le
35k vehicle $250 or so.
2017 1LE Hyper Blue
Old 01-24-2019, 11:08 AM   #14
Hops
Hops's Avatar
Drives: 2019 1ss 1le, blue wrap
i recently priced the following for a scca tracknight with a 10% deductible from Lockton ( i don't think they consider the type of car.. just the amount you're insuring.. but i'll list it anyway):
$10000 for my bmw 128i: $141
$30000 for a v6 1le: $177
$40000 for a 1ss 1le: $229
Hops is offline   Reply With Quote
