12-14-2018, 04:52 PM | #113 |
Drives: SS 6 speed of course Join Date: Jan 2016
thanks for all the work, once again OMG that thing is huge.
12-15-2018, 07:47 AM | #114 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
Ok now i see what your talking about. Lowering the front subframe does seem like the least destructive way to test it.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
12-15-2018, 08:17 AM | #115 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
Perhaps so but, that also sounds like a massive pain in the ass.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
12-15-2018, 08:27 AM | #116 |
Yeah prob would work if you lower the subframe, but man that sucks if u ever have to take it off
12-16-2018, 08:16 PM | #117 |
Drives: 1987 Buick Grand National Join Date: Mar 2016
I don't think this is going to be worth all the work... You might honestly go slower.
12-31-2018, 03:49 PM | #118 | |
FYI, here is a Great site for Specs as well as some upgrade pathways w/ tolerances including numbers. I know I don't have a Camaro however, This is where I went for my 14 Sierra Denali with the L86 (LT1). I was able to use Camaro or Corvette as vehicle searches to build my "Top End". They're basically interchangeable. You can see it's nearly the exact same engine with the exception of the intake manifold and front drive assembly. The LT1 Specs. https://www.onallcylinders.com/2018/...am-specs-more/ L86 Specs. https://www.onallcylinders.com/2018/...am-specs-more/ Also, Fun fact, BBK makes a 92MM Throttle Body for those who want some more HP/TQ. Fits 2016-2019 Camaro SS LT1 6.2L V8 2014-2019 Corvette 6.2L 2014-2019 GM Truck L86 6.2L V8 https://www.bbkperformance.com/92mm-...amaro-lt1.html I just ordered mine. I will update with some data when It's installed. Last edited by Melaasx86; 12-31-2018 at 04:22 PM. Reason: fixing header |
12-31-2018, 04:32 PM | #119 |
03-11-2020, 05:56 AM | #120 |
if You have a e85 kit we may be able to remove the line that’s blocking install
03-11-2020, 08:59 AM | #121 |
@texan.1le
Drives: '18 Camaro 1SS 1LE, PDR Join Date: Jun 2018
This is an interesting development...
'18 1SS 1LE - "Mongoose"
'15 Malibu 2LT - daily |
