03-20-2019, 11:24 PM | #57 |
@NHTFALL
Drives: 2018 Camaro 1SS 1LE Join Date: Apr 2018
I had this clicking on my wheels when I turned. I didn't add anything, just torqued them to Spec (140) and it went away. They were torqued at 120 from dealer.
03-21-2019, 09:52 AM | #58 |
Drives: '18 1SS 1LE Join Date: Sep 2017
Mine were no where near 140 when I took them off for the first time, applied the grease and torqued them when I rotated. Haven't had a nice enough day to see if the noise is gone.
'18 1SS 1LE Black, PDR
03-21-2019, 06:34 PM | #59 |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
Applying more grease to the mating surface seems like an odd solution to me. That's not to say it won't work. IMO, sufficient grease encourages the mating surfaces to slide against each other, so it gets rid of the noise because there's less of an abrupt stick-slip action happening. However, I'd rather not have that movement happening in the first place. My lugs were loose from the factory, and torquing them to spec helped somewhat. I had to corner harder to hear the clicking. However, to fully eliminate the clicking, I found that the mating surfaces have to be spotlessly clean with these wheels. I initially tried just hosing down the surfaces with brake cleaner and wiping it off with a rag. That got rid of the sound on right hand turns, and temporarily eliminated it on left hand turns, but it soon came back on left turns. I finally used some lacquer thinner on a rag and kept wiping down the mating faces thoroughly with clean sections of the rag until the rag was no longer picking up grease. 5000+ miles later, and the clicking has not returned.
Nigel Last edited by Whitespeed; 03-22-2019 at 04:05 AM. |
03-22-2019, 09:25 AM | #60 | |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
MJK3888 Instagram Link
03-25-2019, 08:30 PM | #61 | |
It's possible that there are two causes leading to a similar phenomenon. I'd have to see a more detailed explanation of the mechanisms of the corrosion hypothesis to be convinced, which I've not found in this thread so far. Certainly open to the idea though. But based on current information, I feel confident in concluding that the clicking noise is, in most if not all cases, due to grease on the mating surfaces reducing friction in the clamped joint of the wheel to the hub to the point that a stick-slip action occurs. I suspect that those who still experience the clicking noise after cleaning did not have the mating surfaces cleaned thoroughly enough. Nigel Last edited by Whitespeed; 03-26-2019 at 11:42 AM. Reason: spelling |
08-11-2020, 01:27 PM | #62 | |
Drives: 2020 1SS 1le Join Date: Apr 2019
08-11-2020, 08:39 PM | #63 | |
Still doesn't add up. Where are you seeing corrosion? The 1LE has aluminum brake hats on the front that are anodized and the wheels are aluminum. There should be no corrosion between the mating surfaces. Mating surfaces (front and rear) have to be spotless of grease and lug nuts torqued to 140lbft. As mentioned, a quick clean up on mine did not eliminate the clicking. I've advised others to do the same and it's eliminated the clicking for them. I'm now at 12,000+ miles and over 2 years since doing this myself, with zero clicking. Nigel |
08-12-2020, 08:35 AM | #64 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Guys, I have to agree with Whitespeed. There are multiple problems with the theory that corrosion is the cause and a coating of goop is the solution:
Matt Miller
2020 SS 1LE |
08-12-2020, 09:36 AM | #65 |
Good points...I wondered if anyone tried 145 or even 150ft lbs...I'm unsure the size of the lugs and what they can handle. Just a thought since my previous Mustang spec'd 150 but had the lugs to dictate that setting.
08-12-2020, 04:55 PM | #66 |
The corrosion is between the aluminum wheel and the steel hub centric "pilot" as you call it that centers the rotor and wheel.
My car had the clicking until I rotated the tires and lubed the hub, haven't heard it since. Just something I noticed was the wheels weren't torqued properly when new and making the noise. Ever since they have been torqued to 140ftlb each rotation/wheel swap. I have a set of factory ZL1 wheels and the stock 1LE's.
08-14-2020, 05:00 PM | #67 |
Who Needs to KNOW?
https://www.youtube.com/watch?v=upJQGhnOQEE
I think that is what I am hearing, tick tick tick noise under load. Wheel torqued to 140 ft-lbs ( calibrated digital torque wrench ). Aluminum rotor hat, aluminum wheels. Fairly clean. Ideas ? I'll pull wheel off to make sure wheel bearing is good and no crunchy noises. 22,000 miles on the car. ZLE.
ing for grip.
08-17-2020, 05:41 PM | #68 |
I heard it I think today when turning the wheel to lock while stationary. I haven't heard any tick tick tick under load or while driving. Was kind of a clunk sound vs tick.
08-17-2020, 07:03 PM | #69 |
The noise happens while moving, making a turn. Mine seemed to be at about 30mph during a sharp turn.
Click, click, click, click. rapidly like three to four clicks per second depending on speed.
08-17-2020, 11:07 PM | #70 |
Drives: 2018 2SS 1LE Join Date: Feb 2018
Had this on my 16. You just have to keep going back to dealer and eventually they either apply enough grease or do something else to fix it
2018 1LE
2nd 6th gen SPL Toe Arms/Brembo HTC64t/Corsa NPP/Tremec MTF Fluid |
