06-14-2021, 07:45 PM | #1 |
Drives: Chevy camaro Join Date: Oct 2020
How do I figure out what mods are on my ZL1
Okay ladies and gents, I have a Camaro ZL1 I scored for a great price…it definitely has a cam but the seller claimed it had head work completed too: LME heads, ported bronze valve guides, 5 axis CNC porting, competition valve job, severe duty exhaust valves, LME dual valve springs.
How do I verify if it has aftermarket heads? Supposedly the supercharger was ported and a 103mm throttle body added….not sure on that either. Car made 660whp on pump 93 and 530whp stock on 93. Let the guessing or schooling begin….thanks, |
06-14-2021, 08:05 PM | #2 | |
'20 ZL1 1LE A10,
06-14-2021, 08:21 PM | #3 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Well if it was stock dyno 530 and now has cam, heads, and ported blower it should be more like 720whp+.
For reference I made 612whp on a mustang dyno with headers, 9.1 pulley and intake. Adding 103 TB, ported SC, cam and meth I made 780whp on the same dyno. I would say, no you don’t have a cam installed. Also look at the TB and you can easily tell if it’s a 103. If so then most likely ported. How does the car sound? How does it drive off idle. That’s another clear way to see if cam or not. |
06-14-2021, 08:40 PM | #4 | |
06-14-2021, 08:52 PM | #5 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
06-14-2021, 08:58 PM | #6 |
06-14-2021, 09:10 PM | #7 |
06-14-2021, 09:16 PM | #8 |
Maybe the compression sucks in one of the cylinders or multiple. Could be losing horsepower
I think I’ll try to get it on a dyno. When a shop dyno’s the car can they get read outs for thing like fuel pressure and compression ratios? Last edited by MooseGoose; 06-14-2021 at 09:28 PM. |
06-15-2021, 07:10 AM | #9 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Ask the PO who did the work and call up that shop and talk to them or ask for email receipts. I can't believe the OP didn't have any documentation on the build for you.
06-15-2021, 08:28 AM | #10 | |
So now I start to wonder what’s ACTUALLY been done to the car other than the obvious intake, pulley, cam and flex fuel kit…. Not sure why someone would add a flex fuel kit on this car with a cam without a fuel system upgrade… |
06-15-2021, 09:03 AM | #11 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Power seems low with those mods and I'm not really up on all of that stuff myself, 660whp seems low.
06-15-2021, 09:43 AM | #12 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
The car could have a JMS voltage booster on the low side. You wouldn't see any evidence of that by looking under the car. If you have a cam, it almost certainly has a 32 or 38% hpfp lobe. You can easily run e60 with a cam and JMS.
Baby Blue
06-15-2021, 10:13 AM | #13 | |
Thank you Al Oppenheiser!
https://www.camaro6.com/forums/showthread.php?t=553575 See also: https://jannettyracing.com/products/...015-camaro-zl1 Exactly. |
06-15-2021, 10:19 AM | #14 | |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
You should call LME and share the VIN or previous owners name, if they built the head they should give you some info. |
