11-07-2020, 05:05 PM | #1 |
Drives: 2016 Camaro Join Date: Oct 2017
18" x 11" Drag Wheel Options?
What are people using for drag wheels?
I'm looking for 18" x 11" with a +43 offset.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
11-10-2020, 09:13 AM | #2 |
Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
11-10-2020, 09:55 AM | #3 |
Thanks, Perdieu! Those Weld Racing wheels are expensive when purchased new. I might keep my eye out for a used pair.
I have a set of slightly-used, older BF Goodrich 295-series drag radials on 10.5-in GTO rims I might bolt-on for sizing. I'm not sure what the center bore is, and I believe the back spacing is too great. I did find Apex Race Parts has some nice rims, but also expensive at $459 each. https://www.apexraceparts.com/store/...-10-wheel.html
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. Last edited by GTO_Gregory; 11-11-2020 at 01:38 AM. Reason: Added Info. |
