09-08-2020, 08:54 PM | #15 | |
11-23-2020, 09:20 AM | #16 |
Drives: p1x 1le Join Date: Jan 2019
good info here. procharged my ss 1le last week so been looking at what my engine can handle
11-23-2020, 09:30 AM | #17 |
Drives: Turbo 6.2 Join Date: Feb 2019
Its not the hp that breaks the lt1 parts, its the torque.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
11-23-2020, 09:41 AM | #18 |
BAMF SS
Figure out the end goal and build a fuel system around that. Dont do the mistake some of us did and replace stuff as it becomee inadequate. With the benefit of hindsight, I would have never got the lt4 stuff, and would of just skipped directly to port injection and used the lt1 fueling stuff. That's just me though
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
11-23-2020, 10:19 AM | #19 | |
2016 NFG 1SS A8
11-23-2020, 10:54 AM | #20 | |
Drives: 2016 Camaro SS Join Date: Sep 2018
11-23-2020, 11:04 AM | #21 | |
A. Do you have a fuel system voltage booster, If not you need one NOW! B. 570 RWHP with a Magnuson is on the Edge, and that is if your Cat overtemp protection fueling is disabled in the tune leaving nothing to protect your cats. If COT is on you will easily exceed the ability of your current fuel system with your current set up. Logging is the only way to know for sure what you have left by monitoring Low side fuel pressure, Must maintain desired. High side fuel pressure, Must maintain desired. Injector Opening time, Must NOT exceed 6 Milliseconds. I strongly recommend a move to a complete LT4 fuel system and JMS fuel system voltage booster before adding any boost. Also consider the Efficiency side of things LT headers High flow exhaust, 95mm Throttle body, Rotofab also. Ted.
www.jannettyracing.com
11-23-2020, 11:20 AM | #22 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Ted, when I was still on LT1 fueling, you put me on a 95mm pulley and ZL1 low side pump. That setup ran great and made 568whp on 93.
Baby Blue
