11-23-2020, 06:47 PM | #267 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Have used the simplest plug in totally adjustable for each gear shift light, the holley sniper that plugs in to your OBD2 diagnostic port. I have used it in multiple cars and can adjust as fine as 50 RPM for the light to come on. You can set up each gear at different RPM. It was a must for me pushing manual cars down the 1/4 mile.
11-24-2020, 12:23 AM | #268 |
Drives: like an old lady Join Date: Jun 2012
the down side to the holley light is the fact it uses the diagnostics port. unless there is a splitter or something to use with it, i don't think one will be able to log via hpt.
11-24-2020, 08:19 AM | #269 | |
11-24-2020, 11:11 AM | #270 |
Yeah I’m not that consistent, I think there’s room with the light. The 1-2 is the hardest and really that one is so fast it’s all about trying to beat the tach with that shift. The others I can glance down and you do it enough you use your ear when to glance down. The tach crossing the 6500 line is what makes it possible. If the target was somewhere else it would be way harder
11-25-2020, 05:48 AM | #271 |
Drives: 2019 Chevrolet Camaro Join Date: Mar 2020
my complete install.
11-25-2020, 07:53 AM | #272 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
11-27-2020, 11:02 AM | #273 |
Drives: 17 SS 1LE, 14 Yukon Denali Join Date: May 2015
Here is mine installed. Had to trim the top of the intake and the bottom of the brace.
11-28-2020, 11:51 AM | #274 |
Drives: 2018 2SS 1LE Join Date: Feb 2018
Is there a verdict on driving these hard without a tune yet? Been following all these threads but for every 5 people that says MAF adjusts there’s one guy who says it runs lean up top.
Worried about running it at 6k at the track constantly if there are lean issues haven’t seen a. Definitive answer yet since so many people are tuning with other mods
2018 1LE
2nd 6th gen SPL Toe Arms/Brembo HTC64t/Corsa NPP/Tremec MTF Fluid |
11-28-2020, 06:43 PM | #275 | |
11-28-2020, 07:06 PM | #276 | |
if you're concerned about the warranty - leave it be.
11-29-2020, 01:57 PM | #277 |
Drives: 2011 2SS/RS & 2017 1SS Join Date: Apr 2011
Just seen that GPI has a black friday sale on the LT2 Intake Manifold.
https://gwatneyperformance.com/cart-share/kjSnt/ref/2/
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE Built/Tuned by Me 2017 Chevrolet Camaro 1SS Auto 9.29 @144.57mph ALL MOTOR SBE #TEAMGPI Gwatney Performance Innovation |
11-29-2020, 05:57 PM | #278 | |
Drives: 17 2SS 6sp Join Date: Jun 2020
11-29-2020, 10:48 PM | #279 | |
Drives: 2018 Camaro SS/1LE Join Date: Jan 2018
2018 SS/1LE... summit white.. E85 ,Ported LT2 IM, Roto Fab, soler performance ported throttle body, secondary delete, mbrp axle back, tuned by CCNC
12-12-2020, 07:26 AM | #280 |
Just a small update. may not be a big issue but wondering if anyone else has noticed that the lt2 corvette intake cover rubs the hoodliner a little bit. May just pull the it out if it gets too bad.
