Old 11-01-2019, 05:47 PM   #99
cirpower
Drives: Camaro ZL1
I put my mount under the brace and washer under other bolt just for a cleaner look. Mine been tight for a year.
Thanks, as always great information, that is similar to how I fitted mine. Do you track your car with high grip tires, e.g. slicks?
cirpower is offline   Reply With Quote
Old 11-01-2019, 05:53 PM   #100
Gary H
Drives: Camaro ZL1
the ADM kit fits nicely under a BMR Brace FYI
Made in the USA. Refined in Great Britain - insta: zl1uk
Velossa intake, Rotofab, Mamo TB, Custom ported NX Lid & Jokerz Full tilt ported LT4 charger, 3 port CoolingMist Meth injection - ATI 15% lower pulley, E2X CC, TSP ceramic coated longtubes, de-cat and Borla 60608 to NPP box, JRE tune, BMR rear control & trailing arms, lock-out kit, lowering springs and front strut brace, Custom carbon trim interior, Xpel ultimate front PPF and Prestige window tint with Chameleon Windscreen tint...ever evolving...
Gary H is offline   Reply With Quote
Old 11-02-2019, 08:36 AM   #101
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Originally Posted by Rodan View Post
The Cordes setup is definitely the best value, but I would prefer the higher placement of the other reservoirs for bleeding.
Also, I'm not really interested in the extra capacity. 1 gallon won't make a significant difference. For HPDE, you're just hauling more hot water around the track.
I just want a small reservoir high up to ease the bleeding issues.
The Cordes tank does a great job of removing air from the system.
Old 11-06-2019, 12:50 PM   #102
Rodan
Rodan's Avatar
Drives: 2018 ZL1 coupe
I found what appears to be a part # for the Edelbrock surge tank: 61-2618
From the Edelbrock site:
From the only place I can find it online:
https://www.good-win-racing.com/Mazd...ml?id=U3Y75wqS
Listed as a replacement part for the Edelbrock MX-5 supercharger kit... $75.00
I have not called Edelbrock to see if they will sell the parts separately, as I have been placed in a time crunch, and may be ordering one of the other options today...
Also, the tank looks quite small, and I don't like the fact that both lines are on the same level...
Rodan is offline   Reply With Quote
Old 11-07-2019, 09:05 AM   #103
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Parts used to mount the reservoir and mate to stock intercooler hoses.
Gates 19839 premolded heater hose U will cut and route $10.00 Orileys
Gates 28479 premolded heater hose U will cut and route $10.00 Orileys
2 5/8 to 3/4 coupler $1.99
2 24mm constant tension spring hose clamps These are black look better $1.00 ea
6 26mm constant tension spring hose clamps $1.00
Edelbrock 51-7100 Tank – black reservoir like Magi or ADM $27.00
Edelbrock 51-7008 Tank lid - $13.00
Edelbrock 79-9177 Tank bracket - needs a bit of mods to attach to strut $35.00
black tank not the clear option!
Old 11-07-2019, 04:10 PM   #104
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Well done!
Thank you!
Old 11-09-2019, 07:32 PM   #105
Rodan
Rodan's Avatar
I installed my ADM kit this afternoon. It's a great kit and an easy install.
I posted a walkthrough to try to consolidate a lot of the info on IC reservoirs, and to show an install with pics.
Install thread is here: https://www.camaro6.com/forums/showt...4#post10657804
Old 11-10-2019, 07:51 AM   #106
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Nice.. I just should you how to do it for 200.00 cheaper.
Old 11-10-2019, 07:54 AM   #107
Rodan
Rodan's Avatar
Nice.. I just showed you how to do it for 200.00 cheaper.
Yeah, I had originally planned the DIY version, but I was in a time crunch with a track event next weekend and didn't want to be sourcing parts from all over the place.
Old 11-10-2019, 09:46 AM   #108
Markoz28
Drives: 18 ZL1 nightfall grey A10
Will most likely go this route if I port the stock SC. Thanks
Markoz28 is offline   Reply With Quote
Old 11-13-2019, 09:59 AM   #109
ProjectZL1
ProjectZL1's Avatar
Drives: 2017 Camaro ZL1
So Just go to the Edelbrock website and enter the part numbers in a search for the edelbrock parts? I may do this, will i need to purchase some sort of heat barrier sleeve to go over the hose like in the ADM kit? Thanks.
ProjectZL1 is offline   Reply With Quote
Old 11-13-2019, 10:08 AM   #110
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Better to call with numbers or go to a resaler
if you want the cover buy by the foot at a hydraulic hose maker place.. I had it on mine then took it off it looks better without and the silver clamps!
Old 11-13-2019, 12:10 PM   #111
ProjectZL1
ProjectZL1's Avatar
Got it, i actually just left their site trying to search and couldn't find anything with those numbers. I will try to call them direct soon.
I was talking about the black heat sleeve on the hoses pictured. I hate silver worm clamps also.
Old 11-13-2019, 12:56 PM   #112
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
its not heat sleeve it stnd hyd sleeve see pic
