01-07-2023, 12:46 PM | #1 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
SS manual transmission fluid
So the manual says GM #88861800- which is manual transmission AND transfer case fluid. Rockauto pulls up a Valvoline MTF synhromesh #811095. A quick search on google pulls up a GM synchromesh #88900333.
I have had no issues with mine in almost 39,000 miles of driving. I would think the GM synchromesh fluid would be an upgrade over the supposed OEM 88861800 fluid. I've tracked mine twice and never had an issue either. I figured it's about time to change it out since the manual says 45,000. Thanks for any input.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
01-07-2023, 05:07 PM | #2 |
At 20 K miles I swapped mine out with Royal Purple Synchromax. Mine has shifted trouble free since then. I think the Valvoline would be fine.
01-07-2023, 08:22 PM | #3 |
Drives: 2021 2SS 1LE Join Date: Aug 2020
MT change interval is 45K street driving, but 15 hrs of track time. So I suppose 1hr of track time = 3K miles of street driving. With 2 track weekends and 40K on the odo, I'd say it's definitely time to change the fluid.
The specs for the fluid are for a certain grade of Dexron ATF (I can't recall offhand), reason being that it needs to be compatible with the metals and other materials in the TR6060. Even if you don't use GM/AC Delco fluid, be sure to stick with a fluid that meets the Dexron rating. |
01-07-2023, 09:21 PM | #4 |
Shifts under load
What I posted is straight from the owners manual.
01-09-2023, 04:44 PM | #5 |
Drives: '23 2SS RSblue 6MT, sold '19 ND2 Join Date: Dec 2021
https://www.tremec.com/anexos/TREMEC_TR-6060_1017.pdf
TR-6060 takes Dexron III. The spec is actually been removed since GM no longer "certifies" this fluid, but GM does sell a "manual transmission fluid." There are many Dex synthetic III equivalents from other oil manufacturers; Redline, Amsoil, Valvoline, etc. Originally Dexron III wasnt fully synthetic.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 |
01-09-2023, 05:00 PM | #6 |
i swapped out mine last year for the first time 6 years and 30k no issues just did oem gm fluid
01-10-2023, 05:32 PM | #7 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I've been doing OEM fluid and my car is 90% track. I followed their guideline and changed the trans fluid after 15 track hours and it literally came out just as new as I put it in.
01-10-2023, 05:33 PM | #8 |
Shifts under load
The manual trans and transfer case fluid?
01-10-2023, 05:52 PM | #9 |
Drives: Cheverolet Camaro Join Date: Jan 2023
Manual Transmission fluid and Rear Differential fluid are 2 things I can think. Because its a front engine rear wheel drive, I cannot think of a transfer case with Manual Transmission. I think transfer cases are supposed to be in 4WD/AWD only , or maybe automatics too. |
01-10-2023, 05:53 PM | #10 |
Shifts under load
That’s what the part number I listed from the owner’s manual comes up as. 88861800
01-10-2023, 07:12 PM | #11 |
01-10-2023, 08:43 PM | #12 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-11-2023, 12:05 AM | #13 | |
I ask because Tremec's fluid is considerably higher viscosity than the OEM, isn't it? Which would potentially provide higher protection on the track, but also more clunkiness on daily drives upon start up and 1st mile or so of driving (especially in cold weather)? Please forgive me if you've shared this previously. |
01-11-2023, 05:43 AM | #14 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
I have a C6 Grand Sport with the TR6060. I have tried the GM fluid, Redline, Royal Purple, and AmsOil.
The AmsOil Torque Drive fluid was the best overall. Has especially good low temp properties and increased the smoothness of shifts. |
