01-30-2023, 10:41 PM | #15 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
The Tremec fluid is much closer in cSt spec to the OEM fluid than many of the aftermarket Dexron 3 type fluids. It's seemed great in my car the past year or two, so I'm leaning towards running that again.
02-02-2023, 02:43 PM | #16 |
Drives: '23 2SS RSblue 6MT, sold '19 ND2 Join Date: Dec 2021
GM put out a bulletin back in like 2007 that said that GM 88861800 replaced Dexoron III as the fill. There are better full synthetic alternatives that meet the spec such as Redline D4 or Amsoil. In the MSDS for this fluid, it lists the 100C viscosity at around 7.5 cST. Redline considers this 70w80 for gear oil https://www.redlineoil.com/d4-atf. I've had great results with Redline oils for MTs and rear LSD.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 Last edited by haggler; 02-02-2023 at 03:04 PM. |
02-02-2023, 02:53 PM | #17 |
Shadow Gray '19 ZLE M6
Interesting thread. I've been using Amsoil Torque-Drive Synthetic ATF.
Kinematic Viscocity @ 100 C = 7.6 Kinematic Viscocity @ 40 C = 37.1
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
02-02-2023, 09:57 PM | #18 | ||
The Dexron III and other aftermarket ATF specs are the outliers here. |
02-02-2023, 11:28 PM | #19 |
The TREMEC fluid is the outlier. The OEM fluid is DEXRON III. Dex3 is no longer licensed, so they changed to that other part #. I'm not saying the TREMEC fluid wont work perfectly, but based on the viscosity sounds like they are specing GL4 75W90.
This is the MSDS for the factory ACDELCO 10-4033 fluid mentioned earlier in this thread. The viscosity is right in line with DEXRON III @ 7.7 cst. Per another oil site ( google this part number and VOA (virgin oil analysis)), there is nothing special about the factory fluid. Since GM is providing the warranty and not TREMEC, if it were me I'd use something meeting Dex III. I've had great results and customer service from Redline, so I will use them for the trans and diff.
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 |
02-03-2023, 10:54 AM | #20 | |
02-05-2023, 08:46 PM | #21 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
I have a little leftover 88861800 from my last change and will send it in for oil analysis to try and put this to bed. It could be it is still a Dexron III spec and the gmparts.com (AC Delco) link has the wrong info as a 75w-90. Since it is still an ATF red tint, I am thinking the gmparts.com info is wrong and its a Dexron III compatible oil.
02-07-2023, 12:14 PM | #22 |
I dont think that MSDS is for the right part number. Nowhere on that sheet does it say any of the correct part numbers. Can you share where you found that? It looks like my previous screenshot was from a 2006 MSDS, below is the newest one I could find.
ACDELCO GM ORIGINAL EQUIPMENT 75W-90 MANUAL TRANSMISSION AND TRANSFER CASE FLUID - 1 QT GM Part # 88861800 ACDelco Part # 10-4033 https://www.brandenburg.com/IphonePD...on%20fluid.pdf Right at the top in small writing it says the correct part number. I have read elsewhere this is made by Petro canada as well. Viscosity Viscosity, kinematic : 34.26 cSt (40 °C / 104 °F) 7.7 cSt (100 °C / 212 °F) More reading material: https://bobistheoilguy.com/forums/th...3/post-5549117 https://bobistheoilguy.com/forums/th...861800.250384/ If you go to GM's part catalog, there is alot of "manual transmission fluid." I would only use the part number spec'd for this TREMEC unit if you're going with OEM fluid. In my case, I will use Redline D4 and its a valid replacement for GM part #88861800. Viscosity is around 7.5cst but full synthetic.
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 Last edited by haggler; 02-07-2023 at 12:32 PM. |
02-07-2023, 08:12 PM | #23 | |
This is where I looked mine up, by searching "transmission", and selecting what seemed to be titled the closest. None of the documents contain the proper part numbers, and nothing populates searching them: https://www.gmparts.com/technical-re...nt-disclosures |
02-09-2023, 03:17 PM | #24 |
The search function on GM's part website seems broken, I just went to the fluids by category. A regular 75w90 gl-4 might work fine given the official TREMEC fluid has a different viscosity, but I'd just use DexIII equivalent or even OEM since GM is the one on the hook for the warranty. I got a while yet before I do the change but this is one fluid you dont want to screw up.
02-11-2023, 02:23 PM | #25 |
IYAOYAS
Drives: 22 1LE 2SS M6 Riverside Blue Join Date: Mar 2018
Personal experience with both redline and tremec manual trans fluids, is that redline d4 is good for cold weather, tremec not as good in cold, but smooth when is warm after driving for 20+ minutes or any day weather is above 60 F.
Redline d4 wasn't impressive on track during warm weather, i have yet to try tremec on the track in warm weather.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold 2018 black Camaro 2SS M6 Redline Edition/Traded 2016 summit white Camaro RS V6 M6/Traded |
02-11-2023, 03:08 PM | #26 | |
02-12-2023, 07:35 PM | #27 | |
IYAOYAS
The Redline D4 on track in warm weather felt very notchy when shifting quick at even high rpms especially in third gear when it was warm after a few laps on a track cross. I figured the reason being that because Redline it is a thinner oil, is good on cold, and the oem m6 trans fluid is a little better during warm season.
