Old 06-20-2019, 07:14 AM   #15
GP86
GP86's Avatar
Drives: 2017 2SS
Originally Posted by RobbyBeefcake87 View Post
I just recently noticed a big dent in my exhaust right after the cats after looking underneath listening for a weird sound. I was just about to make a thread about it and saw this. My question is did the dealership replace your dented exhaust under warranty?
The original replacement was not a warranty replacement. I had a crash where I ran over a huge rock. The exhaust was dented by the rock, so it was replaced as an insurance claim.
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
GP86 is offline   Reply With Quote
Old 06-20-2019, 11:41 AM   #16
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
That X-Pipe is not OEM.
The rust thru looks strange, almost like it was "eaten" or dissolved.
Old 07-05-2019, 08:05 AM   #17
GP86
GP86's Avatar
Drives: 2017 2SS
Just to close this situation, I missed the dealership's phone call but they never called back.
I went to a local shop and had him weld the original piece back in for $85.
Old 07-07-2019, 12:23 AM   #18
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
yes that is the factory X pipe. that is a factory exhaust . dealer will replace
Old 07-07-2019, 01:35 AM   #19
bignaz
Drives: 2019 ZL1 1LE
Thats weird. I got a buddy with a 17 SS in Michigan daily driver even in the winter on salty roads and he's probably only washed it 2 times since he bought it new and I asked him to check his out and he said his is fine.
bignaz is offline   Reply With Quote
Old 07-14-2019, 11:43 AM   #20
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
OK - the section that was replaced "appears" to be replaced with regular pipe, NOT SS.
Agree that is the OEM X pipe.
Old 07-15-2019, 07:01 AM   #21
JCunningham
Drives: 2017 2SS M6
the pics the op posted are of a factory exhaust
Old 07-15-2019, 07:03 AM   #22
ScatPack
ScatPack's Avatar
Drives: None at the moment
Looks like they were repeatedly scraped on something and they wore through. Maybe you were bottoming out somewhere everyday on the way to work? Thats 304 stainless, and it doesnt rust.
ScatPack is offline   Reply With Quote
Old 07-15-2019, 07:30 AM   #23
VinnAY
Drives: 18 1SS/1LE
Thats the low spot in what was standard probably at the best galvanized steel, never drove it enough to dry it out; short trips possibly. Water pooled there and easily corroded until it failed.
Old 07-16-2019, 01:08 PM   #24
MackSteelPrivateEye
Should be under warranty.
Old 10-06-2019, 10:17 AM   #25
GP86
GP86's Avatar
Drives: 2017 2SS
Final update on this for those who are interested. The dealer, Suburban Chevrolet in Ann Arbor, Michigan completely ghosted me on this. They never returned my calls and never offered any kind of fix. I've been unhappy with every other service they provided on my car, so I expected nothing less.
I found a local shop who cleaned it up and re-welded the original piece back in for $80.
Old 10-06-2019, 10:55 AM   #26
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
I would have them go through the whole exhaust, and make sure all of the hangers and brackets are in place. For a piece like that to come off in the way that it did my suspicion would be that there is excessive Flex or movement in the exhaust system that fatigued and broke them loose.
Zaqwert6 is offline   Reply With Quote
Old 10-06-2019, 11:47 AM   #27
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
I would contact GM right away and let them know everything. Don't give up.
camaroJD is offline   Reply With Quote
Old 10-06-2019, 11:54 AM   #28
Broadway
Drives: 2018 Camaro SS
I am having same issue with my car, although my bracket didn't come completely off like yours, just cracked along the aft end of the right weld. Got a terrible rattle and exhaust leak. Took it to the dealership in May, they said they had to order new bracket. They still haven't gotten it in yet, or done anything. Called GM customer support to see if they could expedite the process or help in any other way, and they have been basically useless
Broadway is offline   Reply With Quote
