01-08-2020, 03:33 PM | #1 |
Drives: 2020 Red Hot 2SS Join Date: Nov 2019
Pressure washing / foam cannon
Apologies if this is a stupid question - I've watched youtube vids and read online but can't figure it out.
I have a pressure washer which I bought to clean the deck with, and I just got a foam cannon attachment for it. So now I want to try it out and wash the car, but I am afraid of stripping the paint when I rinse the car off. I have the following pressure washer (in case that tells you anything about the nozzle): https://www.amazon.com/Sun-Joe-SPX15.../dp/B079YYBDT7 How do I make sure I don't strip the paint? I read somewhere that different nozzles are sold (25 and 45 degrees?). Do I need to buy those adapters, or can I use the one that comes with the pressure washer? If so, how do I know how much pressure to apply? |
01-08-2020, 03:41 PM | #2 |
Drives: 2019 1LE Join Date: Nov 2019
Love mine!
01-08-2020, 04:14 PM | #3 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
I have a pressure regulator on the wand, would recommend getting one. Home Depot or similar carries them
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
01-08-2020, 05:22 PM | #4 |
01-08-2020, 09:18 PM | #5 |
I usually set it about half way but I think we are not talking the same thing.
This is what I use https://www.amazon.com/Powercare-AP3...18369582&psc=1
2019 Crush A10
01-08-2020, 10:08 PM | #6 |
Drives: 2018 ZL1 Join Date: Dec 2017
I would not worry, a little common sense, keep the wand (tip) 10-12 inches from the car with 35* to rinse to start. 45* tip for finish rinse. I have the same pressure washer for the last 2 years with zero issues. If you didn’t get the other tips, I think they are on Amazon.
01-09-2020, 03:13 PM | #7 | |
01-09-2020, 03:18 PM | #8 | |
https://snowjoe.imgix.net/product-fe...&fm=webp&w=500 As for the pressure washer, im glad it's lasted that long - I got it on sale for ~$60, couldn't pass up that deal. |
01-09-2020, 04:04 PM | #9 |
Mine is not adjustable, but it came with a 10*, a 25*, 35*, and a 45* nozzle. If memory serves it is a 1700 psi washer, vs my 4500 psi Honda!
01-09-2020, 04:21 PM | #10 |
Drives: 2017 ZL1 Join Date: Mar 2014
FYI: this is the foam attachment that is inserted onto the end of the wand of the pressure washer.
You want to avoid spraying high pressure water directly on the car. |
01-09-2020, 06:09 PM | #11 |
Hey, thanks! This is exactly what I bought. I understand this is only used to cover the car in foam. My concern is for when it's time to rinse off the foam. To rinse it, I assume I have to take off this tip, and put on the regular wand that came with the washer. I am just having trouble understanding what setting (angle) to use during the rinse-off step.
01-09-2020, 06:22 PM | #12 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Using a hose and the "pooling" method you will have fewer water spots.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
01-10-2020, 10:47 AM | #13 | |
01-10-2020, 04:15 PM | #14 |
Drives: 2019 Red Hot 1SS "Scarlett" Join Date: Jul 2019
I want a pressure washer just so I can use a foam cannon. So much better than a foam gun.
I use a brass hose valve so I can shut the water off and change attachments. You could also use a quick connector. |
Thread Tools | |
