Old 10-27-2019, 09:28 AM   #323
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Ran Sebring Friday with the DTC-70 front and back with titanium shims. Worked like a champ, less pressure required which took a bit to get use to... Still have life left in front rings, so the DBS rings will wait a few more events...
Timbo-1LE is offline   Reply With Quote
Old 11-15-2019, 06:58 PM   #324
Yomike951
Yomike951's Avatar
Drives: 2019 ZL1 1LE
I run the Hawk DTC 70 front and 60 rear.
Yomike951 is offline   Reply With Quote
Old 04-09-2020, 03:02 PM   #325
Redlinez
Shifts under load
Redlinez's Avatar
Originally Posted by carguy55 View Post
Interesting Coby Shield just won the Street GT class season at Glidlife Time Attack using PowerStop Track day pads all season. (one of his sponsors)
Cost for complete set = $185 at RockAuto
I assume he's using the PST series. The rear listing isn't very specific and only lists one PST rear pad set. I'm pretty sure rear brakes are the same on the standard SS and the 1LE.
22 Suzuki GSX-S 1000GT blue
Old 04-09-2020, 03:46 PM   #326
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Yes, Power Stop Track day pads are the PST pads as shown in post #1. I've used them. They're very inexpensive and work well, but are also very high dust to the point of your car is covered after one track session.
Old 04-09-2020, 05:01 PM   #327
Redlinez
Shifts under load
Redlinez's Avatar
No big deal, I would just wash it after the HPDE is over. Ain't like we aren't used to brake dust with the stock Brembos. The price on those is crazy cheap. compared to Hawk and others.
Old 04-10-2020, 01:23 PM   #328
tmalaquin
Drives: Blue ss 1le 18
Just bought a full set of DTC-70s, still wondering if I need to add shims or no, any thoughts ? using MOTUL RBF 600.
Also, is there any risks triggering ABS under heavy braking with the OEM tires and those Pads ?
18 ss 1LE
Cheers,
TM
tmalaquin is offline   Reply With Quote
Old 04-10-2020, 01:37 PM   #329
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i used the powerstop track day pads at the track 3 times in the last year and they do dust like crazy but had pretty good stopping power ...just recently upgraded to a zzp bbk kit on the front and im back on stock pads/rotors for now but they are more than enough for my driving
Old 06-18-2020, 10:59 AM   #330
davidwarren
Drives: 2019 SS 1LE
how many track days are you guys getting out of the stock 1LE rotor rings?
davidwarren is offline   Reply With Quote
Old 06-18-2020, 11:06 AM   #331
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
I went 2 years with 15k miles. Around 500 AutoX runs and 26 track days at Daytona, Sebring, The FIRM and PBIR.
I swapped mine for heat checking, not being worn or lipped.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 06-18-2020, 03:26 PM   #332
cdrptrks
cdrptrks's Avatar
Do you have any pics of the amount of heat checking?
Mine came with heat checks when I bought the car used but with stock brake pads they haven't gotten noticeably worse so far after 14 track days and they are still above minimum thickness. I have had a new set of rotors standing by since last year if the heat checks start looking longer or reaching the edges but haven't needed them yet.
Old 06-18-2020, 05:46 PM   #333
TrackClub
TrackClub's Avatar
That's the beauty of stock pads: they don't throw tons of heat. You can post a pic of yout rotors here, or just check they dont start to separate (so your nail catches), dont link up and most important: dont start runnung to the outside. Otherwise, i would not worry about them too much. Cheers!
Old 06-18-2020, 06:54 PM   #334
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Plus, you can buy them lightly used dirt cheap and kind of pre-burnished!
RUQWIKR is offline   Reply With Quote
Old 08-12-2020, 01:12 PM   #335
brzaro
brzaro's Avatar
Drives: '20 SS 1LE
Lots of great info on this thread - thank you all for sharing!
Does anyone have experience with Pagid RSL29 on our cars? I ran DTC-60s at Watkins for 3 days and they're 85% done. Pagids are double the price but if they last more than a few track events would be worth it.
I used to run RS29s on previous cars and they were excellent but switched to PFC08 and never looked back. If anyone knows where I can get some 08s that'd be even better.
brzaro is offline   Reply With Quote
Old 09-24-2020, 09:23 PM   #336
weemus
Drives: 2017 1SS 1LE
Resurrection: Anyone use ST47s? Anyone use them on all 4 corners? Lastly anyone drive on the street with them?
weemus is offline   Reply With Quote
