07-19-2019, 10:50 AM | #15 | |
Drives: E92 BMW M3 Join Date: Oct 2012
J-Rod Built and Matt@FSP Tuned |
07-19-2019, 10:53 AM | #16 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
yup, that would be a no brainer. They should do that next year.
07-19-2019, 11:10 AM | #17 | ||
Moderator.ca
However, if it requires the new electrical architecture GM developed for the C8 it might not be backwards compatible into old platforms like Alpha. *edit* To the OP, why wait 3 years to put that engine into a Z/28 anyway? If it can be done at all for the 6th gen, why not put it into the Camaro as soon as possible.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
07-19-2019, 11:22 AM | #18 |
Drives: 15 RH Z/28, 23 RB2SS1LE, 23LT1VOM Join Date: Dec 2012
Camaro is going away, no more Z/28, but think there is a solid chance you will get an LT2 in an SS before the curtain falls. Now an LT2 SS1LE would be a very potent car for the $$ JMHO.
07-19-2019, 11:23 AM | #19 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
It’s powertrain hardware - shouldn’t require the new electric architecture to control. |
07-19-2019, 11:38 AM | #20 |
Drives: 21 Bronco Join Date: Jun 2012
I would think that if they can drop the LT2 in easily they will. Much like the C6 did when they dropped the LS2 for the LS3
07-19-2019, 11:40 AM | #21 | |
Moderator.ca
Now, on the flip side, it is entirely possible that even if the data protocols are radically different on the new electrical system, GM could either translate the data from the Camaro into something that works for the LT2 or they could re-work the engine control module so that works in a Camaro (more extensively than they'd normally have to at least). And of course, I could be entirely off base on all this and it turns out that making the LT2 work in a Camaro is a trivial exercise.
07-19-2019, 11:58 AM | #22 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
So many variables...now will they even advertise the car on tv
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
07-19-2019, 12:14 PM | #23 | |
Again, I think (and believe me I really have no clue here) even if they have to do some R&D and rework some stuff, this would be fairly low risk and would be a great way to extend (and maybe more profitable than perhaps a whole new Gen7) the current 6th Gen, vs. not have a Camaro at all. For Gen 7, whenever that occurs, I think GM will have to make the Camaro more practical to drive, a la (i hate to say) the Challenger. More visibility, roomier back seat.
07-19-2019, 12:17 PM | #24 | |
07-19-2019, 12:23 PM | #25 |
07-19-2019, 12:41 PM | #26 |
If Chevy has no intent of producing a 7th gen Camaro, then forget the engine, it isn't worth any money spent towards making it happen.
Assuming the engine can be put into that car with relatively little work (aside from all the testing and tuning to make sure the MRC, and traction control type goodies are calibrated for the extra forces that come from extra power), then GM would be completely stupid for not putting it in the Camaro. The Challenger and Mustang both offer higher HP models than the Camaro (without including Shelby or Hellcat models)...... So in the interest of competition, there is no logical answer for not putting this motor into the car. We shall see what happens.
07-19-2019, 01:15 PM | #27 | ||
What I am saying is that the engine, itself, has no absolute tie to the C8 architecture. The intake, exhaust, ignition, etc, are all things that could be "tuned-in" to work with the Camaro's engine controller and adjusted to the Camaro's current systems; if anything, a similar part that is compatible with the Camaro's system could be used for the data input/output. It's not like there are specific sensors, throttle bodies and whatnot made specifically for the LT2/C8 combination that HAVE to be used otherwise you cant control the LT2 (thus making the LT2 exclusive to the C8). It's still a Gen V, LT-family, OHV V8... Quote:
I think the Camaro, if and when a 7th gen eventually comes out, will be a new animal from what is used to... Last edited by Mountain; 07-19-2019 at 01:35 PM. |
07-19-2019, 01:31 PM | #28 |
Motortrend has some good pictures of C8. Here are some of the LT2. The one very realistic thing that would keep the LT2 from the Camaro is this: engine orientation: on the LT2, the intake faces towards the rear; if the intake can simply be rotated around and will bolt up no problem - fine. But, if it will require a new intake, it will take sharing the LT2 on a larger volume program to justify investment into a new intake and also re-certifying the engine power numbers (amongst re-cerifying the car's fuel economy and emissions).
