Old 06-17-2019, 07:51 PM   #1
VADER332
VADER332's Avatar
Drives: 2019 ZL1 1LE / 2014 Ford Raptor
Made a few passes
My setup is a 2017 Camaro 2SS A8, stock
The tires are 285/305 Nitto NT555G2 on MRR 017 20” wheels.
I turned the T/C off and launched around idle each time.
I let air out of the rear tires to 30 psi after a lot of tire spin during the first run.
My second run was better, not too much tire spin.
VADER332 is offline   Reply With Quote
Old 06-23-2019, 10:07 PM   #2
Silverado53
Silverado53's Avatar
Drives: 2010 2ss M6
Hey vader, good too see a fellow local on here.
I had the nightfall gray procharged 6th gen.
2015 Camaro 1ss M6
Stage 4 BTR Cam FBO
500 W/HP N/A Build
-----SOLD-----
2017 Camaro 1ss A8
P1x Procharged
Texas Speed long tubes
624WHP----572wtq
--------SOLD---------
3 year break- Had twins LOL.
2010 Camaro 2ss M6
Stock... Not for long
Silverado53 is offline   Reply With Quote
Old 06-24-2019, 03:42 PM   #3
VADER332
VADER332's Avatar
Man. I remember you. We were parked close to each other, same section.
Old 06-24-2019, 04:16 PM   #4
Umbriel
Drives: 2016 Camaro SS
What was the DA? 13.7 @ 106 mph is really bad for one of these cars.
Umbriel is offline   Reply With Quote
Old 06-24-2019, 08:51 PM   #5
VADER332
VADER332's Avatar
The DA at 19:00 was 1166 ft. The poor run probably had more to do with me than the car.
Old 06-24-2019, 09:48 PM   #6
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
With a little practice, you should be able to get a full 1.5 seconds off your time while adding 8-10 MPH, bone stock. That DA isn’t bad, but if it’s better that will obviously help.
Joshinator99 is online now   Reply With Quote
Old 06-25-2019, 06:41 AM   #7
Umbriel
Unless you were letting off going down the track I don't see how your car is only trapping 106 mph. I've never seen one of them trap that low and the DA isn't horrible.
Sent from my SM-G955U using Tapatalk
Old 06-25-2019, 07:31 AM   #8
gaveup
Drives: 2019 Camaro ZL1 M6
Is only 81mph in the 1/8th a problem to you guys? That seems pretty low especially for an automatic where most driving is taken out of the equation. Unless TC was severely limiting you, your traps should be higher.
Your car gained 25mph in the backend which is normal, but you should be trapping close to 90mph at the 1/8th to give you comparable times to other stock cars.
gaveup is offline   Reply With Quote
Old 06-25-2019, 02:54 PM   #9
VADER332
VADER332's Avatar
Thanks for the advice. Your right, more seat time should help me.
Old 06-25-2019, 06:44 PM   #10
Joshinator99
No problem! FWIW, I aired my stock rear tires down into the low 20’s and the traction wasn’t bad (when I was stock). Might be worth a try instead of the 30# you’re running now.
Old 08-10-2019, 10:23 PM   #11
Jverado
Jverado's Avatar
Drives: 2004 Silverado, 2020 ZL1
You can also try the launch control. It has been getting me consistent 12.4-12.5. I tried launching without it at 1800 and spun bad. Some have said their best times have been from idle and without launch control.
Jverado is offline   Reply With Quote
Old 08-11-2019, 06:59 AM   #12
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
When mine was stock my first pass was 12.05@116, my best pass that day was 12.04. That was on stock run flat tires. DA was about the same and temps in the low 70's. I left right off idle after a burn out in the water box. Those numbers are way off what most of these cars run in the good air. I tried other launches at 1000, 1500 and none were better then off idle flat footing it. Go out and give it a shot again.
Old 08-11-2019, 02:44 PM   #13
Jverado
Jverado's Avatar
Well that's good to know. I will try that next time. My IAT was getting really high and it was pulling some timing too. Next trip I'll throw some Octane booster in, let it cool more between runs and try what you're saying. So it hooks up when you do that?
Old 08-11-2019, 05:25 PM   #14
laynlo15
laynlo15's Avatar
If the track is prepped and you do a burn out as I did.
