11-27-2022, 12:37 PM | #1 |
Drives: Chevy Camaro Join Date: Jan 2021
IAT's Post Meth
With the Magnuson 2300 what is the best way to read IAT's post meth. I know they make a breakout harness, I just help install one on my buddies Procharged Camaro. I want to say I read somewhere thou that you can change the map sensor on the back of the blower to a lt4 style... I'm not sure any help will be appreciated.
2017 Camaro SS TMS 416, TSP Ported Heads, Magnuson TVS2300
11-27-2022, 12:57 PM | #2 |
Exactly where is this sensor located?
'20 ZL1 1LE A10,
11-27-2022, 01:12 PM | #3 |
Back of blower on the driver side
11-27-2022, 01:49 PM | #4 | |
Procharger base kits do not include a breakout harness and use the correct map sensor (LS9 3 bar) so the ECU can properly read boost. Which is completely Asinine imo. This is why your buddy added one. Note LT4 cars are different for anybody with a ZL1 or Z06 reading this.
2016 NFG 1SS A8
11-27-2022, 01:56 PM | #5 |
Ok... your right there is a BO harness there. So its already reading IAT's post meth.
11-27-2022, 02:11 PM | #6 |
I need to find that post... but Im positive that the 3 bar sensor does not read IAT's but the LT4 4 bar does. Im under the understanding that the IAT's are being read from the MAF sensor now.
11-27-2022, 03:57 PM | #7 |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
The LT4 TMAP reads manifold temperature and pressure, unfortunately it's normally not located in a good location to measure temperature (a static airflow location is better for MAP) so it generally doesn't respond quickly for a good temperature reading - at least on a PD SC.
11-27-2022, 05:13 PM | #8 |
Correct, but I thought most PD setups run the LT4 map... at least mine does. Centri cars run the LS9 map.
2016 NFG 1SS A8
11-27-2022, 05:53 PM | #9 |
hmmm... I guess I need to do some more research on figuring out what I need to do then because I really want to read my IAT's post meth.
11-27-2022, 06:12 PM | #10 |
Put a LT4 map in place of the LS9 and change the tune for it.
2016 NFG 1SS A8
11-27-2022, 06:29 PM | #11 |
Thanks!!
11-27-2022, 10:13 PM | #12 |
That is correct, the LT4 Maggie does use the TMAP, but with a breakout harness for moving the MAT to a different location.
11-27-2022, 10:17 PM | #13 | |
I've honestly don't think I noticed a huge temp difference with meth added on my 2300, but knock disappears and I could add more timing/boost.
11-27-2022, 10:35 PM | #14 |
If you have E85 in your area I'd ditch the Meth, consider the THPSI port injection for your 2300 as I did. I ran Meth/water on my 16 SS with 2300 and 2650. After finding out about the Port Injection and how it's made my car run I'd never run Meth again. Just sayin
