10-02-2022, 08:08 AM | #1 |
So lets see if we can go 9s on a 20" drag radial. What? Another fib?
So, Josh was always right about me, I never tell the truth in the beginning about my next build. Ok so lets just get it to go mid 11s and we almost did with 11.64. Then I get a blower and toohighpsi Port Injection and lets just try and go 10.60s and we go 10.34 and I'm happy with that, Right? Nope, so lets try and go in the 9s on stock front tires, 305 35 20 555r2s on stock wheels on the rear on the stock fuel system except the JMS booster. That is what we'll find out Oct 15, outlook on the weather looks to be about 68 degrees and I'm thinking DA will be 0 to 500 which are ideal conditions for a good opportunity to do that. Can the tires handle it, not sure. Can the axles and driveshaft handle, that's also an unknown. If I get close on 20s but not there yet, I'll buy a Hoosier Slick drag pack before the last race of the year and save the 100 lbs and I'm sure we can do it with that. I know I'm going to hear it from Josh and probably King about my problems with never being fast enough. I admit it and my wife knows it also, I have some issues to deal with at 70.7 years old. Never say never.
10-02-2022, 08:19 AM | #2 | |
You are walking in knowing stuff might break, so its a great stress test too. Im curious what the first broken link will be. The pistons? The driveshaft? Looking forward to seeing you push the limits!
10-02-2022, 08:26 AM | #3 |
Drives: 98 Camaro Join Date: Apr 2022
You’re not far off. The good air and a good launch and it should be close. The good thing the 20’s have going for them is the tire height is pretty respectable at 28” +- I say you get it if the track prep/conditions are respectable that day. Good luck
10-02-2022, 08:28 AM | #4 | |
10-02-2022, 08:52 AM | #5 |
Hey no worries my friend. Just a little friendly ball busting!
I started having trouble hooking with the 20” drag radials in the 10.3-10.5 range. I didn’t think to try launching in 2nd gear back then, but I probably could have cracked into the 9’s back then on 20’s if I had. Not sure if your current TCM tune will allow you to try a 2nd gear launch?
10-02-2022, 09:42 AM | #6 | |
I can't second gear launch with this trans being stock and locked. Mike worked on figuring out the timing to get the car past 60 ft without blowing the tires off like I did at the fest after the first pass. We can adjust from there. I can always leave the traction control on and see if it will launch that way. Mike swears I had it on with the first pass at the LS Fest, I did my burnout in touring with it off, then switched to sport but didn't click to turn it off in that mode. Just not sure but it pulled like 9 degrees of timing on the launch from 18 degrees to 9 degrees. So we have the launch at 9 degrees and see if these R2s can hold it.
10-02-2022, 10:25 AM | #7 |
Lots of 9s (and maybe 8s) have been run on 19" drag radials (Nitto, Toyo, and others) on ZL1 and 1LE so I don't see a reason you can't do it.
'20 ZL1 1LE A10,
10-02-2022, 11:56 AM | #8 |
I agree, gonna try.
10-02-2022, 01:04 PM | #9 | |
Good luck my friend! You’re so close, it’s definitely looking good.
10-02-2022, 02:09 PM | #10 |
I know others have run in the 9s on 20" drag radial but have they run in the 9s with stock Lt1 fuel system. I know I have an aid in the Jms booster but still have the Lt1 HPFP, stock injectors and stock in tank pump. I had a lot of fuel mods on my 16 to run 10.00@139 so maybe we can do it on stock stuff and heavier then stock.
10-03-2022, 08:11 AM | #11 | |
'20 ZL1 1LE A10,
10-03-2022, 08:44 AM | #12 |
Yes I am, the 15th, 22nd and 29th are the last 3 races. Possibly into early November but the depends on weather here in Missouri. Wwtraceway or Gateway is my home track and its 155 miles away from me. Its actually in Madison Ill just across the river from St Louis arch. Where are you at?
10-03-2022, 08:48 AM | #13 | |
Here is the schedule I'll be running the Pro/Sportsman combo 1/8 mile and the VP Heads Up 1/4 in probably Class A which is the quick 8, maybe Class B depending on the number of cars there. Its usually a pretty big field in the street classes.
10-03-2022, 11:53 AM | #14 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
This is the exciting part where all the work pays off
It's much more dialed in now with 10x better conditions. Running 9's on port injection and a set of R2's on the back will be super impressive. 12 more days
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
