07-20-2022, 04:11 PM | #1 |
Drives: 2018 Camaro RS 3.6L Join Date: Apr 2022
SS Springs on a v6 Rs
Has anyone swapped springs from a 6 gen SS without magnetic ride to a 6 gen RS?
My thinking is that since the SS is a little bit heavier maybe the springs will be a bit stiffer in the corners. Those that have done it, what are your thoughts? TIA |
07-21-2022, 11:43 AM | #2 | |
Drives: 2022 Kia Stinger GT2 Join Date: Oct 2019
Have you looked at the V6 1LE? If I recall correctly, it used the suspension from the base SS. So it may be worth researching people's feeling on that to get a general idea of how the swap would feel. I never did the swap, so I can't add any more the the discussion. |
07-21-2022, 12:36 PM | #3 |
Drives: 2016 2SS Convertible Join Date: May 2012
It might also change the ride height. Maybe some of the other V6 1LE suspension components will would help you achieve what you’re looking for if you don’t already have them installed on your car?
07-25-2022, 12:02 PM | #4 |
Drives: 2020 1SS 1LE M6 was 2018 V6 RS A8 Join Date: May 2018
The front springs are specific to the engine weight, transmission type, and suspension tune. Lots of different springs came on these cars. See here.
I'd try swapping in FE3 parts for a V6 1LE to eliminate the possibility of a ride height that's too high. That way you could also eventually change springs, front and rear sway bars, front struts, sway bar links, toe links, rear shocks, then SS tires and wheels and maybe even some of the suspension braces that are on the V6 1LE. There's more specific info here. I seem to remember that the V6 1LE has the same front springs as what you already have, but I'd double check that. Last edited by DriftNDraft; 07-25-2022 at 12:29 PM. |
10-20-2022, 12:54 PM | #5 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
I have 1SS shocks and rear springs with BMR front springs (and 1SS front/rear sway bars) in case any of you are looking to try it out.
I'm in Gainesville, GA Would probably be a nice upgrade
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
10-20-2022, 09:03 PM | #6 |
Drives: '21 V6 1LE Join Date: Jul 2020
While the V6 1LE has the FE3 suspension, I believe it is slightly different than the one on the SS (like maybe different spring rates or something) due to different car weights.
I'd go either that route or aftermarket. But I'm curious what your goal is here. |
10-23-2022, 12:33 AM | #7 |
Long hauler
v6 1LE does have specific front springs, the rear springs are the same as the SS. I bought both and they had different part numbers, ended up using neither and used Eibach Pro.
01-13-2023, 02:00 PM | #8 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
Thread bump..
I searched as best I could and couldn't find an answer - Is there a chart that lists all the spring rates for all the suspension codes? Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
01-13-2023, 06:36 PM | #9 | |
01-13-2023, 08:22 PM | #10 | |
I'm thinking new project and it would be great to know the spring rates without having all the trial and error. Ken
01-14-2023, 10:10 AM | #11 |
Long hauler
Spring rates
v6/I4
Front = 124 lbs/inch (Linear) Rear = 467 lbs/inch (Linear) v6(/I4?) 1LE Front = Unknown Rear = 577 lbs/inch (Linear) SS Front = 137 lbs/inch (Linear) Rear = 577 lbs/inch (Linear) SS 1LE Front = 178 lbs/inch (Linear) Rear = 539 lbs/inch (Linear) https://www.camaro6.com/forums/showthread.php?t=475647 https://www.camaro6.com/forums/showp...6&postcount=20
