06-18-2022, 03:39 PM | #1 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
My car is honking at me as I’m tracking it!! what’s going on?!
I was driving my car hard around the track for the first time in about 1.5 years, and all of a sudden, seemingly randomly, my horn starts honking at me intermittently from time to time. I am absolutely sure I was not accidentally hitting the horn myself, my hands were exactly where they are supposed to be on the steering wheel. WTF?!
This happened a few times in the 2 1/2 sessions I tracked the car yesterday before the car started to misfire and the check engine light came on. I doubt they’re related but I thought I might as well include all the information just in case. The car also said “upshift required, engine protection mode on” but it’s an auto that was never in manual mode… when I cleared the message it never came back… I am now ordering a new set of upgraded spark plug wires and plugs considering I have 2 inch long tube headers Buts that’s a lot of odd stuff that happened. Any thought?!
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
06-18-2022, 03:57 PM | #2 |
Sounds like electrical gremlins from partially damaged wires or a loose connector... if you can think back, did the unexpected stuff always happen in similar turns at relatively high g's with the steering wheel locked to one end (or close to it)? Are your tires and wheels stock?
Also, since you are probably tuned for the headers, you should data log your runs with VCM scanner, identifying these problem spots may give you useful clues.
06-18-2022, 08:28 PM | #3 |
Drives: 1SS 1LE Join Date: Jul 2018
Maybe it’s just happy to be back on track after a year and a half *laughs*
06-20-2022, 12:38 PM | #4 | |
So far I’ve been told it could be a electrical ground issue; a wire not secured properly after the long tube headers were installed, so that’s what I’m gonna get checked first
06-20-2022, 12:39 PM | #5 |
I wish!
06-21-2022, 02:52 PM | #6 |
Drives: 2021 Camaro LT1 Join Date: Oct 2020
my car honks at me when i reprogram the TPMS. Maybe you are triggering something on the TPMS setup on the track.
06-22-2022, 12:57 AM | #7 | |
Or maybe it’s the fact that I put my key fob in the centre consul with my cell phone And it was making contact
06-24-2022, 10:08 AM | #8 |
So it turns out the misfiring is primarily being caused by the Kooks GESI green cats having melted after just two 20 minute track sessions, very disappointed that they failed so fast.
Also the spark plugs and spark plug wires were in horrible condition according to the dealership I take my car to. But I guess that’s not a surprise considering I have long tube headers on the car, despite that they are ceramic coated.
07-04-2022, 11:43 PM | #9 |
OK so it wasn’t my key fob causing the horn honking, it happened again but this time on the street and my key fob was in my pocket with absolutely nothing touching it.
Obviously this thread should not be in the road course and track section, i’m not sure if a moderator will see this and move it or how to contact a moderator to move it
07-05-2022, 08:39 AM | #10 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
have you noticed it happening more on left turns/right turns or will it just do it in a straight line? Has to be some sort of bad connection somewhere making a phantom "horn press" I would think.
07-05-2022, 09:45 AM | #11 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
So just incase I figure I mention it , you have 2" headers did your installer move the wiring harness on the passenger side. There been a couple guy that melted them because they did reroute the harness.
07-06-2022, 12:04 PM | #12 |
Seems to be on left hand corners, but it happens so infrequently that I cannot replicate it, though I have not been to the track again yet... The dealership already checked the the steering wheel regarding faulty connections but found no issue
07-06-2022, 12:08 PM | #13 | |
My mechanics did find a wiring harness melting against the exhaust after the headers, but they said that was because the exhaust shop that did the work for the dealership (when removing my GESI cats) did not strap it up and out of the way properly which is why I'm getting a heat bank DCT code coming up since the car came back from the dealership last week.
07-06-2022, 02:33 PM | #14 |
Thank you Al Oppenheiser!
Yep, that'll do it. While you're at it, you might want to also check for arcing plug wires, which can cause seemingly random intermittent misbehavior with the various electronics.
