![]() Drives: 2018 Chevy Camaro ss 1LE Join Date: May 2020
ZL1 1LE rear adjustable sway at on a SS1LE
Has anyone tried to put the adjustable ZL1 1LE on a SS 1LE
I want to dial out the factory understeer, built into the SS1LE, any recommendations I track my car, and that understeer, is slowing me down in decreasing radius turns. |
![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
Push gas pedal more.
![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
I've not tried it, but I'd assume just swapping the bar on it's own would be too much rear bar. If you haven't, try getting the track alignment first. That should get you very close to neutral. From there you can play with tire pressure settings.
Also, what drive mode are you using to track the car? If you're in anything lower than PTM Sport 2 you'll have ESC interventions that will cause the car to understeer more.
2017 SS 1LE. Summit White.
#4 | |
Have not done the track alignment. Because I also drive the car to and from track, and on streets. Figured, that would kill my tires, 2deg negative camber, driving 3-4 hrs each way. Thank you that was helpful |
![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
The car does have slight understeer balance even with track alignment and all nannies off, but it also allows more trail braking and getting on the gas earlier after the apex. I'm not experienced enough to tell if a stiffer rear bar would be helpful or not. I'd like to try it but the car is pretty awesome the way it is and I don't find myself wishing for more oversteer balance very often in autox.
#6 | |
My car is 100% stock, including tires. I think I might try running in full track mode, and kick out the rear, with rear the throttle, in the tight turns. |
#7 |
![]() Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
two things...
1) PTM race will still have traction control. you can slide it but you wont be able to hold much power on when the rear tires start to slip. 2) the ZLE rear bar in full stiff is softer than the SS 1LE bar. ZLE uses stiffer springs so a softer bar was used on that. Another member here has already done the swap and it made the understeer worse when compared to the SS1LE bar. A popular combo for the guys tracking is the Hotchkis front bar and the BMR rear bar. Several people have reported really good results with that combo both in Autocross and Track.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
#8 | |
A little more neutral, would be much better for my driving style. I thought in full track mode, everything is off, if not you can alway turn of T/C with the button on console |
#9 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
#10 | |
The car will feel more nimble in this setting compared to any of the PTM modes. |
#11 | |
I guess there is a reason for all those electronics, (so you do not crash the car) |
#12 |
![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
Yep, came here to say this. Go with a BMR rear bar.
#13 |
![]() Drives: SS 1LE Join Date: Oct 2017
The wonky alignment that comes on them from the factory will kill your tires much, much faster than track alignment. My tires are wearing much more evenly with the track alignment despite tons of daily driving on the streets. Would recommend getting the alignment done before you change the sway bar.
#14 | |
Might just do that. Does anyone know an alignment shop on Long Island. I heard horror stories if you don’t take to a good race shop |
Thread Tools | |
