Old 12-27-2023, 01:33 PM   #1
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1 & 2022 Hayabusa
ARH 2" Headers
I picked these up a year or so ago with intentions of installing, but I just haven't taken the time to and with surgery coming up I'm planning on staying stock and find an axle back.
They do have flat spots on bottom and a couple small cracks at the weld. I intended to weld and install, I daily my car and know I'd probably flatten a new pair of headers anyways.
Asking $600, buyer pays shipping. Or pick up, located in Louisiana.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook
- Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels
- +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc...
infinitereality is offline   Reply With Quote
Old 02-18-2024, 10:57 AM   #2
blue_chew_energy
Drives: 22 SS 1LE 6MT
Did these ever sell?
blue_chew_energy is offline   Reply With Quote
Old 02-18-2024, 12:08 PM   #3
infinitereality
Still available, just shot you a message.
Old 02-29-2024, 08:34 AM   #4
blue_chew_energy
Hello Del. I sent you a PM.
Old 03-15-2024, 03:25 PM   #5
Sillysspeed
Drives: 98 Camaro
What connection pipe do these use?
Sillysspeed is offline   Reply With Quote
Old 03-18-2024, 10:03 AM   #6
infinitereality
They are not modified from ARH. Slip fit with band clamp, but of course could be cut off for a v-band if wanted. I can provide dimensions if you'd like?
There's 1 ARH clamp included for sure. The other may have fallen off when I store them and didn't notice till now. I'll check and confirm to update the thread if both are there.
Old 04-02-2024, 06:28 AM   #7
infinitereality
There's only the one band clamp.
Old 04-02-2024, 08:38 AM   #8
Ericdared
Drives: 2022 Camaro zl1
https://ibb.co/p4VW0dM
That's not a crack is it?
Edit: Sorry can't figure out how to get images to work here. Tried using the attach image thing and it isn't showing up so here is a direct link to it.
Ericdared is offline   Reply With Quote
Old 04-02-2024, 01:25 PM   #9
infinitereality
Negative on that, just a scrape from getting removed. Only cracks are in the close-up pics
