09-29-2020, 07:31 PM | #1 |
Drives: 2017 Camaro SS Join Date: Jun 2020
Camaro Vibration...frustrated.
Hello -
Bit of a double-post...I posted this in the Camaro5 forum before seeing Camaro 6 one... First post here I've owned (2nd owner) my 2017 Camaro SS 3 months now. Had a blast with it so far, but getting frustrated with a vibration issue that the Chevy Dealer close to me has been unable to diagnose. While accelerating, at any speed, or maintaining speed by having my foot on the gas or using cruise control, my Camaro has short vibrations. The entire car vibrates for 2-3 seconds, then stops, then a few seconds later it vibrates again. It's not a vibration that make the car wobble violently, but it's like running over the rumble stripes on the shoulder of the road, but lighter. If I step off the gas peddle or shut off cruise control while the vibration is occurring, it stops immediately. If I driving fast enough and let off the gas and coast for a bit, it doesn't happen. Another observation is that the car will drive for a bit with no vibration, but once the first vibration happens, it continues to happen frequently. Not sure if I am going crazy, but it seems like when the vibration occurs, the RPM pointer jumps slightly, then goes back down when the vibration ends. Pretty sure it's not the tires since the vibration doesn't occur when I let of the gas and coast. The usual karma, the dealership said they didn't feel the vibration while driving it. It's getting to the point where I'm not enjoying driving this car because the vibration happens on and off pretty much every time I drive it now. Any guesses as to what is going on? Or ideas I can suggest to the dealership to check? Thank you! |
09-29-2020, 07:38 PM | #2 | |
2020 Shadow Gray 2SS
https://www.camaro6.com/forums/showt...hlight=Shudder https://www.camaro6.com/forums/showt...hlight=Shudder
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
09-29-2020, 07:38 PM | #3 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
Sounds like shudder. If it has the A8 then get it checked out at a dealer that deals with A8 shudder.
09-29-2020, 07:49 PM | #4 |
Thanks for the replies. It is an automatic and has just under 7K miles on it. I'll check out the A8 shudder threads!
09-29-2020, 07:57 PM | #5 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
This A8 shudder is extremely common unfortunately. It should've been listed on the window sticker when buying anything with the GM A8 lol
09-29-2020, 08:20 PM | #6 |
I'm starting to think mine might be an A10. Is it safe to assume the same problem exists with it as the A8's?
Looking through my documentation that came with the car to confirm it's an A10, but not seeing it yet. |
09-29-2020, 08:31 PM | #7 |
You have a 2017 SS right? If so, it's an A8
09-29-2020, 08:33 PM | #8 |
09-29-2020, 08:40 PM | #9 |
And here is the thing....even if you don't have the A8 shudder at the moment (you most likely do though) you should still get the latest fluid and flush procedure done as good preventive maintenance.
09-29-2020, 10:46 PM | #10 |
The A10 wasn't introduced in the SS until the 2019 model year, your 2017 is VERY definitely an A8...
09-29-2020, 11:37 PM | #11 |
Drives: Chevrolet Camaro SS 2018 Join Date: Jun 2019
Wait, you've had the car for 3 months and not sure if you have an 8 speed or 10? You never once put it in manual mode and shifted with paddles? Or like read the brochure? Not hating but this is pretty weird lol. Weirder still though, is the dealer not knowing instantly what is by far the most common auto Camaro problem, and not using the right instrument to pick up on it while driving, which should've immediately given results.
09-29-2020, 11:59 PM | #12 | |
09-30-2020, 06:01 AM | #13 |
Yes it is the infamous shudder problem. Take it to the dealer, tell them what it is doing and have it flushed with the new fluid
09-30-2020, 06:44 AM | #14 |
Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
2017 was a bad year for the A8 shudder. I bought a brand new 2017 RS and it had exactly what you describe. At the time there was really no fix- they tried flushing, etc. The car spent more time at the dealership that I did driving it. Mine had it so bad it was like driving over rumble strips, shaking the entire car.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
