Old 12-05-2019, 06:56 AM   #1
rspitler
rspitler's Avatar
Drives: 2017 SS Convertible
Check Engine Light
CEL came on this week. Called On-Star and there are 2 codes set. A P0700 and a B3109. P0700 is transmission related but I can't find a clear reference for the B3109. Anyone know what this code is for?
Anyway, dealer appointment tomorrow......
rspitler is offline   Reply With Quote
Old 12-05-2019, 07:21 AM   #2
Cechk01
Drives: 2016 Camaro 2SS M6
Key less entry low battery
https://www.dtcdecode.com/Chevrolet/B3109-00
Cechk01 is offline   Reply With Quote
Old 12-05-2019, 08:18 AM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
I had a keyless entry system glitch 18 months ago that left the ignition on with the car completely dark ... and it killed the battery overnight.
The car threw the exact same pair of codes. Got two emails from onstar: one telling me to charge the car (too late) and the second to to take it to the dealer, which I of course ignored.
I jumped the car, cleared the codes and charged the battery. Never happened again.
Old 12-05-2019, 09:49 AM   #4
rspitler
rspitler's Avatar
Originally Posted by Cechk01 View Post
I've replaced the battery about 2 months ago.
Old 12-07-2019, 09:42 PM   #5
rspitler
rspitler's Avatar
Trans temp sensor for the P0700
Old 12-09-2019, 09:10 PM   #6
IAI80
Drives: 2016 1LT V6 A8
I just had the trans fluid temp sensor replaced. It was a check engine light and code p0711. I guess that sensor is buried. They had to pull the transmission pan and the valve body out to get at it. Fluid changed out again because of all that. Luckily it was covered under warranty. Hope it doesn’t happen again.
IAI80 is offline   Reply With Quote
Old 12-10-2019, 05:42 PM   #7
honus03
Drives: 1979 Camaro. 2016 2LT/RS V6
I had the same codes codes pop up on my car. They went away the next day and haven't come backl since, but I'm getting my sensor changed out at the dealership on Monday. Hopefully it won't take them too long.
honus03 is offline   Reply With Quote
Old 12-12-2019, 07:08 AM   #8
rspitler
rspitler's Avatar
Been a week and dealer is unable to track down a temp sensor. At least I have a loaner....
Old 12-12-2019, 09:51 PM   #9
IAI80
Yes still in the wake of the GM strike the dealer gave me the impression that it was a stroke of luck they had the sensor. Some other part to the fix, I forget what, they had to scrounge up from another dealer across town.
Old 12-27-2019, 09:08 AM   #10
rspitler
rspitler's Avatar
Got the car back this morning. 3 weeks in the shop. Seems to run better? Not sure yet. Shifting does seem to be smoother......
Old 12-20-2020, 01:10 PM   #11
RxSummit16
Drives: 2016 Summit White Camaro LT2 RS
Just got the p0711...any idea if its ok to drive until it can be replaced?
2016 Camaro 2LT | 3.6L V6 | A/T | Summit White | JWM Smoked Side Markers | Flowmaster American Thunder Axle-back Exhaust | K&N Filter | AIRAID Modular Intake Tube | Overkill Tune
RxSummit16 is offline   Reply With Quote
