Old 01-04-2021, 07:48 PM   #1
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
Switchblade key fob non camaro
My daughters car wouldn't start this morning. She dropped the keys and broke the fob and was trying to start it with just the metal key. Is there something in the fob that disables the ignition?
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91
Bo White throttle body Magnaflow Competition Exhaust
12.391 112 MPH 10/05/19
StingrayblueSS is offline   Reply With Quote
Old 01-04-2021, 07:49 PM   #2
StingrayblueSS
2011 Equinox btw.
2013 Camaro SS
Old 01-04-2021, 09:05 PM   #3
Camaro__ss
Drives: 2013 L99
The transponder for the flip key is in the fob. If the transponder is damaged or not correctly positioned the car won’t start.
Does the spare key work? If so, it is fairly easy to program another transponder key after its cut by the dealer as long as you have one working key (spare).
You can also remove the switchblade key from the non-working fob and put it on a new fob and program that. Just need a working key.
Camaro__ss is offline   Reply With Quote
Old 01-04-2021, 09:19 PM   #4
StingrayblueSS
Well I put the key back together and it started. Thanks, there may be a recall on it like on the Camaro I'll check it out.
2013 Camaro SS
