01-24-2020, 07:24 PM | #15 |
That is exactly what I did. I bought 2 brand new fobs on Amazon, removed the blank keys, installed mine after cutting them out of the plastic crap and then reprogrammed them. Everything works including remote start.
01-24-2020, 11:47 PM | #16 |
Drives: ABM #93 Join Date: Oct 2018
I’ve got the amazon switchblade here as a spare. I’ve not had the recall done and have no plans to in the future.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
01-25-2020, 05:55 AM | #17 | |
Drives: 2018 1SS M6 Join Date: Nov 2014
01-26-2020, 09:47 PM | #18 | |
Drives: 2010 SS A/T Join Date: Jan 2020
Hmmm, Shall check into that this week. Thanks.
"Those who hammer their guns into plowshares will plow for those who do not" Thomas Jefferson
"Thosewho would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety."Benjamin Franklin |
01-26-2020, 11:38 PM | #19 |
Drives: 2012 2SS Victory Red with white st Join Date: Jun 2016
You were able to go and get new switchblades at the dealer for a while. Now in most areas it is under a second recall because they found out people were getting them and can not do so now. Just call the dealer and ask (don't mention a recall) and see which one you can get. Or go the amazon route
01-27-2020, 06:27 AM | #20 | |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
03-26-2020, 10:25 PM | #21 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
Switch Blade key fob Replacement
I am pretty sure this topic has been over visited, however I wanted to share. Recently one of my remote buttons on my remote decided to fall out. I called a dealership and they wanted $250.00 and would not make it a switchblade style. I was ok and started to google search where I could get a new remote. I ended up ordering from Walmart.com. I was skeptical how good they would be as they were only $25.00 for 2. With my surprise they were a perfect match to my OEM ones. I then called ACE hardware to see how much it would cost to have the blanks cut to my OEM key, $50.00. I was like nope, so I pulled the little pin that I discovered holding the key to the remote and just put my cut key onto my new remote. Programming both was super easy as well.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
03-27-2020, 02:29 AM | #22 |
Hey, is the lock in the door supposed to read the key? If I arm the car, and open the
door with the key, the alarm sounds. I was told it was coded to the car, they lied. |
03-27-2020, 04:59 AM | #23 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
If you lock the doors with the transmitter, the alarm will go off unless you unlock the doors with the transmitter
03-27-2020, 11:33 AM | #24 | |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
I like it! The "recall fix" sucks - they key is always bouncing off my knee now. I am going to sacrifice one of my recall keys today to try this as you outlined. I've got a roll pin assortment set!!! |
03-27-2020, 01:03 PM | #25 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
Never had the recall done. So, 10 years later It's not a problem.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
