Old 04-24-2016, 08:03 AM   #15
Illmaticz
Illmaticz's Avatar
Drives: 2020 Camaro ZL1-1LE
I was wondering if this would have any impact on the ECU ? I could just imagine my local dealer giving me BS on how these products can harm the system.
Illmaticz is offline   Reply With Quote
Old 04-24-2016, 05:24 PM   #16
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
This changes nothing within the ECU itself, it modifies how the pedal sends voltage to the ECU that is still within range of the stock variances. It simply changes how much and how quickly it is sent.
Sledgehammer70 is offline   Reply With Quote
Old 04-29-2016, 11:53 AM   #17
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
Does this eliminate the dead zone of the gas peddle? there is a few centimeters of play that does nothing when the gas peddle is depressed, and I want to get rid of it, and I'm hoping this does that for me. ?
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
Old 04-29-2016, 12:02 PM   #18
MGD
MGD's Avatar
Drives: 16 Camaro SS
The Controller will not eliminate the mechanical play in the pedal itself. I don't know if there is a adjustment for it or not. I have the same thing. Will take a look at it on Saturday on how to eliminate the the play.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 04-29-2016, 12:17 PM   #19
Techn9cian805
The BEAST
bummer. I hate that play, it makes starting off feel unnatural with the manual.
Old 04-29-2016, 12:27 PM   #20
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
I get the feeling that the dead zone or non-linear behavior of the peddle is a safety feature to eliminate the chance that a oem throttle could be on the upper end of tolerance and put out voltage while the peddle isn't being pressed. (wild guess)
In either case, it feels very non-linear until you are pushing the peddle passed it. Like you push down and nothing, then you get a little something but then it just goes straight to "i'm alive" as you try to compensate for the car not moving as much as you expect it to. It feels less like the part has play and more like the ECU is tuned to respond that way.
I'd expect this throttle addon to mask that behavior since the amount of peddle travel is reduced so it would be harder to put the peddle in that initial range with that behavior.
Old 05-07-2016, 04:31 AM   #21
Sledgehammer70
Lethal Camaro
When you watch your own guide because you lost the instructions
Old 06-21-2016, 06:08 PM   #22
TenSeven
Drives: 2016 Camaro SS
I just learned the throttle pedal and base are a unit that is very easily removed. On the base of the throttle assembly, pop off the rubber cover and remove the 10mm bolt. slide the whole assembly back about 1/2" and it's freed from the floor.
Now you can easily access the plug and wiring you need to replace for the VTC installation.
TenSeven is offline   Reply With Quote
Old 06-23-2016, 12:54 AM   #23
tward
tward's Avatar
Drives: 99 Corvette, 68 Camaro, 03 350Z
I also did this when I installed my VTC. The best reason to do this is it gives you access to the factory hole in the carpet to run (hide) the VTC harness, unless you prefer the ghetto look of the harness running on top of your carpet.
2016 Camaro 2SS: Garnet Red Tint Coat, Jet Black Interior, A8 Auto, MRC, NPP, Nav and 5-Split Spoke Silver Rims.
tward is offline   Reply With Quote
Old 07-02-2016, 04:18 PM   #24
rdmeyers
rdmeyers's Avatar
Can I set this up once, then forget about it? Or do I have to adjust the level each startup? In other words, say I set it to SP5 will it stay there forever unless I change it? I ask this as it will determine where I mount the unit.
2SS Coupe | M6 | Garnet Red Tintcoat w/ Black Metallic Rally Stripes | Adrenaline Red Interior & Knee Pads | Sunroof | Black 5 Spoke Wheels | Black Bowties | Performance Exhaust | Navigation
rdmeyers is offline   Reply With Quote
Old 07-02-2016, 05:33 PM   #25
Sledgehammer70
Lethal Camaro
The setup is once when you install it. The SP setting is a quick push of the buttons after that.
Old 07-03-2016, 04:50 PM   #26
rdmeyers
rdmeyers's Avatar
I understand that the initial setup is a one-time thing. Do I have to set the SP level each and every time I start the engine?
Old 07-03-2016, 06:31 PM   #27
Sledgehammer70
Lethal Camaro
Not. It will stay at whatever setting you last left it.
Old 07-21-2016, 03:36 PM   #28
Cldgin2
Cldgin2's Avatar
Drives: 2017 1LE SS
Here in Vegas one of our club members kept throwing codes. He said it was this throttle controller and kind of stopped me from ordering one. The dealer told him after they reset his codes twice now, one more time and they wont fix it. He told me they knew (even though he removed the vitesse) that he was using one, as the computer reports when something is plugged in?????
Still on the fence. I want one, but I don't want codes, and I don't want threats of things not getting fixed under warranty.
Suggestions?
'If one day the speed kills me, don't cry. Because I was smiling.' - Paul Walker
Cldgin2 is offline   Reply With Quote
