Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 12-04-2020, 05:04 AM   #15
jimmyp
Drives: 2013 Camaro Convertible
Last Question. Anyone know if there's a difference between the back half of an SS manual driveshaft or an Automatic? Not Sure if they're different lengths?
jimmyp is offline   Reply With Quote
Old 12-04-2020, 06:11 AM   #16
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Driveshafts are different lengths but I can't tell you for sure if it's the front of rear part of the shaft.
Sent from my Pixel XL using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
larry_g is offline   Reply With Quote
Old 12-04-2020, 06:54 PM   #17
Pearlj10
Drives: 2011 Camaro 2LT
The length of the rear shaft is different, as is the bolt up pattern.
Pearlj10 is offline   Reply With Quote
Old 07-22-2023, 08:48 PM   #18
Ck1984
Drives: 2015 camaro LFX V6
SO to do this swap you just need the
1. used or new center pumpking with LSD in it and hopelly much faster gears than stock V6 rearend but also both corresponding
2. new /used axles to go with new pumpkin.
the old brake calipers, rotors etc bolt right up?
3. the front 1/2 old driveshaft works too maybe with different back 1/2? i wonder how much most wreckers would charge for just back 1/2 of driveshaft versus a new aluminum driveshaft that sposed to reduce rotating mass a fair bit?
plus new gear oil n additive and that is complete parts list?
2015 2LT LFX 3.6L
FE2 Sport Suspension
MXO-6 Speed auto w/Tapshift
Aftermarket Oval mufflers
Ck1984 is offline   Reply With Quote
