10-13-2017, 02:02 PM | #1 |
Drives: 17' 1SS A8 Join Date: Jan 2017
my ac wont turn (power light wont turn on either)
so basically my ac will not turn on and digital temp light wont turn on either. Pretty much my bottom half of my dash is dead. what can this be?
2017 1ss e85 /Rotofab/ Ported IM/TB Texas Speed 1 7/8th long tube headers with off road connection
10-13-2017, 02:07 PM | #2 |
Drives: 2016 Camaro 2SS, 6spd M Join Date: Aug 2016
Have you checked the fuse?
10-13-2017, 02:15 PM | #3 |
I have but maybe im checking the wrong fuse lol do you guys know what number it is? and is it the fuse box under the hood?
10-13-2017, 02:25 PM | #4 |
Well, not sure, but in the engine fuse box check F52 and K8, and in the trunk fuse box (near amp, under carpet, middle of trunk) check F2 and F14.
10-13-2017, 02:26 PM | #5 | |
Thanks bro I’ll check that and let you know ! Sent from my iPhone using Tapatalk
10-13-2017, 02:28 PM | #6 |
Drives: '22 Silverado 2500HD Duramax LTZ Join Date: Dec 2015
If the fuses are good, try a reset by unhooking the battery for 10 minutes.... this has helped others with their issues....
Worth a try....
10-13-2017, 04:43 PM | #7 | |
ahhh i tried that , no go for me. thanks
06-15-2021, 08:07 PM | #8 |
Drives: 2017 Silver SS Convertible Join Date: Dec 2018
06-16-2021, 10:47 AM | #9 | |
"bottom half of the dash is dead" sounds like a harness connection problem. |
06-16-2021, 12:37 PM | #10 |
Drives: 1968 SS/RS, 2006 H2 2016 2SS White Join Date: Sep 2015
AC not running at all or blowing hot?
2016 2SS White fully loaded
06-16-2021, 12:40 PM | #11 |
06-16-2021, 04:43 PM | #12 |
Drives: '16 2SS M6 Join Date: Aug 2019
You will need to get it scanned, but will have to do it with a scanner that can read the Body Control Modules. There could be a few things causing a problem. For instance, the HVAC Module is under the dash on the passenger side. If it's bad and needs to be replaced, it has to be programmed by the dealer or someone that has an interface and a subscription to GM's service portal.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
06-17-2021, 07:35 AM | #13 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
This thread is 4 years old. I would think it is fixed by now.
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
06-17-2021, 09:45 AM | #14 |
Thread Tools | |
