09-27-2018, 09:48 PM | #29 |
I realize that... but for proper tire wear on normal street driving what's on the door is always on the low end. I'll stick closer to the max.
09-27-2018, 10:15 PM | #30 |
Who Needs to KNOW?
I run 4S... 32-34 psi is fine. tire wear is controlled by right pedal.. for most part.
ing for grip.
09-28-2018, 07:40 AM | #31 |
Drives: 2000 GMPPSV SS & 2017 ILE SS Join Date: Jul 2017
09-28-2018, 08:54 AM | #32 |
Any pics
Pretty sure I'm going to put these on my extra set of ZLE wheels. |
09-28-2018, 09:17 AM | #33 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
The listed tire pressures on the door jamb are going to give the best combination of tire performance attributes, including wear. If you're doing highly loaded and/or high speed driving, then there are charts for tire load ratings to determine how much the tire pressure should be raised.
09-28-2018, 08:13 PM | #34 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Correct, if you go to the tire manufactures sight and find your tire it will have the tires max weight load rating. That is for 1 tire, then find out the # for all 4 tires and that gives you the max load all of your tires can hold or handle at the max air pressure. Example here, the SS 1LE GY F1 Gen 3 tires are rated at 1521lbs for the front and 1709lbs for the rear, that means the entire set can handle 6460lbs at the max inflation pressure of 50psi for the front and 51psi for the rear. That is the weight for the car, the fluids, the occupants, stuff in the car and so on. If the 1LE weighs 3750lbs and with a driver and stuff you have another 300lbs then you are at 4050lbs. 4050lbs is 62% of the max weight of the tire. The front tires are rates at 50 psi, the rears are 51 psi. 60% of the front tires max psi is 31 psi, the rears is 31.62 or 32 psi. That is off the hip from me guessing that GM figures on 300lbs in addition to the vehicle weight. That is pretty dang close to the door card info and suggestion. So again, running max psi based on the tires sidewall is not the best way to adjust air pressure. It should be done based on how the tire is wearing, with the factory suggesting 32psi I would start from there, I highly doubt you will need more than +/- 2psi for daily street driving over what the factory suggested.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
09-28-2018, 08:25 PM | #35 |
Now that I went and looked, replacing the stock tires with the Michelin Pilot 4S puts you at 1984lbs for the front and 1929lbs for the rears for the max weight or 7826 for the total weight. Max PSI is 50 for the front and rears.
Same 4050lbs for the 1LE weight is 52% of the max weight the tires can handle, at 50psi with 52% of the pressure that puts you at 26psi roughly in each tire. 26psi might be a smidge low as I am not sure what the trip point is for the TPMS system. Still I tend use the wear pattern on the tire as a good judge of if the tire is running enough pressure or not and adjust from there.
09-28-2018, 08:30 PM | #36 | |
10-14-2018, 09:50 AM | #37 | |
Drives: 2017 1LE Join Date: Nov 2017
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
