10-11-2018, 06:53 PM | #29 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2018
might be a dumb question, but how can i tell if mine are loose?
Current:
2018 1SS 1LE - stock Past: 2008 C6 - heads/cam/boltons 2005 GTO - cam/boltons |
10-11-2018, 08:20 PM | #30 |
Mine sounded like a clunking noise when going over a slightly bumpy road at about 25 mpth. Usually comes from the right front top nut. If you take the front wheels off you can check them all but it can be a PITA since it has a allen head stud. The bottom nuts were even more difficult to get to, I recommend taking it to the dealer and have them replaced since it's a TSB. Make sure they use the nuts on the TSB and torque to spec.
Last edited by carguy55; 12-27-2018 at 01:04 PM. Reason: took out locktite since I didn't need to use any with lock nuts |
12-26-2018, 06:27 AM | #31 |
Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
12-26-2018, 06:28 AM | #32 |
12-26-2018, 06:32 AM | #33 |
You don’t need locktite with selfies locking nuts. These are used on aircraft all the time and they don’t come loose. Just sayin.
12-27-2018, 09:16 AM | #34 |
Drives: 2017 1LE Join Date: Nov 2017
Didn't have this problem. Tech did check when alignment done and he said it was fine. Mine was built May ' 17 if that is a factor. I've not noticed issue tied to production dates.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
12-27-2018, 10:39 AM | #35 |
i have upgraded powergrid ones and afe power swaybars finally got them all tight and good to go lol but still get them checked every few months
