09-10-2020, 07:23 PM | #1 |
Drives: 2010 Camaro SS A6 Join Date: Oct 2018
Warming up Nitto drag radials in cooler weather
Hi all. Last weekend I made 5 runs at the dragstrip at a bracket race and I spun during three of those runs on the launch. It was upper 60s here in MI. My burnout was the same as throughout the summer where I didn't spin on the launch. My question is, with the cooler weather coming here in MI, should I heat the tires up more or should I lower the rear tire psi some? Or, should I do both???
09-10-2020, 08:45 PM | #2 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
The rubber compound in Nittos get really hard in cooler weather. Lots of hot/cold cycles also makes them harder. They also turn to mush if you overheat them. I'd suggest burning them down and swapping to MTs.
09-11-2020, 04:27 PM | #3 |
Thinks Vegas. I'll try to heat them up more as we approach cooler weather. I'll need new tires next spring so maybe I'll switch to the Mickeys!!!
11-30-2020, 09:09 AM | #4 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I got about 15-20 runs from my Nitto dr's. I found the Nitto's like to be run hot. At $600 a set it's an expensive track day lol.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
12-07-2020, 10:49 AM | #5 |
Drives: 2011 Camaro SS Join Date: Jul 2019
12-07-2020, 10:53 AM | #6 |
Yes no doubt. I'm going to try Mickey Thompson next season.
12-15-2020, 05:25 PM | #7 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
They all need some heat, get some real smoke off them to make them work.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
01-04-2021, 02:30 AM | #8 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
John force style but dry burn out
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
01-04-2021, 07:12 PM | #9 |
Js2fst/Pro Stock John, one thing that I did do "near the end of the season" last year was pull a tad farther out of the water box onto completely dry pavement and then burn them a little more to see more smoke. This seemed to help heat up the tires better and give me better grip off the line. To verify this statement, when we got into our fall mini series in Oct., I won the last race of the year. Never spun once
01-04-2021, 08:34 PM | #10 |
Can't see why people can't hook with nittos. Once I got my pressure and burn out duration locked in my car just hooked and took off at the light. No spin at all. And on the street they were flawless. Each tire has its preferred optimum operating parameters. You need to experiment and find where it is for your driving style.
