04-07-2020, 05:41 PM | #1 |
Drives: 2019 Corvette GS, 2023 ZL1 Join Date: Mar 2009
I'm confused on what the hell this is!
I had some brake work done a bit ago and just look at my car closely. What is going on? What are the little wheels on my caliper? On both front. I don't think I have ever seen anything like this before. Any help is appreciated!!! Thanks!!!
04-07-2020, 05:51 PM | #2 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Anyone with these, we call them roller skates. They are on there for balance I believe. If you and when you change your brake pads you don't have to put the same kind of OEM pads on.
When I put new ceramic pads on mine I ordered they didn't come wirh the rollers. I got ahold of where I bought them after some searching. Found out I didn't need the skates. And I have never had a problem with my brakes. Hitting 100MPH and stopping very quick with no problems.
04-07-2020, 05:59 PM | #3 |
https://www.summitracing.com/parts/ado-171-1112
The detail says "steel strands to provide strength and conduct heat away from the rotor's surface" They're heatsinks... |
04-07-2020, 06:01 PM | #4 |
Hmmmm interesting! I didn't ask for them and I don't think I have ever seen them before. I would think it would be safe to assume that you would get identical replacement parts! Thank you for the info!!!
04-07-2020, 06:05 PM | #5 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
They are not for balance nor are they heatsinks....
The actual reason for the "roller skates" was an attempt to reduce the noise that the OEM Brembo pads are known for.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
04-07-2020, 06:07 PM | #6 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
In short, you got "the good stuff"
04-07-2020, 06:08 PM | #7 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
04-07-2020, 06:10 PM | #8 |
A noise that I have never noticed once in ten years!!
04-07-2020, 06:13 PM | #9 |
Drives: cheby Camaro Join Date: Aug 2019
Relax those are actually there to reduce braking noise.
04-07-2020, 06:20 PM | #10 |
Drives: Chevrolet Camaro Join Date: Mar 2020
I have those brakes on my Camaro would like to know the part# for front and back?
04-07-2020, 06:32 PM | #11 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
The purpose of them are as others have stated, they are to reduce noise and also to help with vibration. However I do not think they work. Just my opinion.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
04-07-2020, 06:34 PM | #12 |
Instagram: Sangstah
That's standard issue on later year brake pads.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
04-07-2020, 07:15 PM | #13 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I've got them. They work. I'd say they're worth at least 15hp lol
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
04-07-2020, 07:40 PM | #14 |
It don’t come easy.
Before the roller skates, they did this. Wheel weights.
Is this what I think it is?
