04-30-2018, 10:22 AM | #1 | |
Drives: 2012 45th SS Join Date: Sep 2010
Huron Speed Twin Turbo Stock Bottom End goes 9.92 @ 139
My personal car, first time with the car ever to the track yesterday. Just wanted to share the set-up and the results!
2010 Camaro SS Stock bottom end Texas Speed VVT-3 n/a Camshaft in the car when I purchased Ported Heads Huron Speed Twin Turbo Kit, base intercooler, EXA pump, muffler-less exhaust, Precision 5858cea turbos Squash Dual pumps with stock feed line and rails ID1300's e85 RPM 4l80-e conversion 17" Bogarts w/ Hoosiers Stock suspension w/ lowering springs Full weight, full interior, A/C blowing cold, front sway bar still on and hooked up Only used the foot brake yesterday and would leave at 0 vacuum, no boost 15 psi the car made 775/803 rwhp, tuned by Dr. Phil 9.92 @ 138.95 1/4 6.41 @ 115.49 1/8 1.56 60' Next time out I will begin messing with the 2-step and trans brake! |
04-30-2018, 10:34 AM | #2 |
So awesome, congrats!
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM |
04-30-2018, 11:18 AM | #3 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
Great times. Do you feel like that's the limit of those turbos?
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
04-30-2018, 12:31 PM | #4 |
...not a marine biologist
Drives: 2012 Camaro RY SS LS3 Join Date: Mar 2013
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com |
04-30-2018, 01:21 PM | #5 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Nice run! Great looking car! Congrats!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
04-30-2018, 01:44 PM | #6 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Doesn't get much better than that!!! Awesome!
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
04-30-2018, 03:39 PM | #7 |
Based on the dyno graph I would say they are close. These are the smallest turbos for the kit. They light so quickly which is apparent by the 60' times leaving in vacuum. We can squeeze a little more out of the turbos before swapping them out, and have a lot of work to do in the 60' with the trans brake and 2-step. I believe we can get it into the mid 9's with more seat time
04-30-2018, 05:23 PM | #8 |
Nice job Jon I agree think should pick up some with the trans brake and 2 step will be interesting Good Luck. your kit it awesome very easy install cant wait to get 17s on car
05-01-2018, 09:43 PM | #9 |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
How much did your IAT's rise on a pass?
05-02-2018, 03:38 AM | #10 |
Drives: 2012 V6 Camaro 2010 Camaro SS Join Date: Jun 2010
Congratulations very nice results!
Mr. Clean
05-02-2018, 07:26 AM | #11 |
Drives: 2014 SS 1LE Join Date: Apr 2014
Nice. Makes me want to go auto even more
05-02-2018, 01:22 PM | #12 |
05-02-2018, 01:22 PM | #13 |
Thanks guys, hope to get back this weekend and mess with the trans brake!
05-02-2018, 05:18 PM | #14 |
Drives: T Join Date: Mar 2015
Sweet run! Lookin good
