03-23-2017, 02:10 PM | #1 |
Sparky
Drives: 2017 50th Coupe / 2017 ZL1 Join Date: Mar 2017
Non Nav to Nav upgrade
Quick question. Is it a plug and play head swap to install a factory nave unit - or is in more complicated?
Thanks! Mark |
03-23-2017, 04:15 PM | #2 | |
http://www.gen5diy.com/Chevrolet/Cam...grade8-screen/ The real question, is why when you have Android Auto/CarPlay?
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
03-23-2017, 04:42 PM | #3 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
If it's more complicated that using a usb cable to attach your phone to the port in the center console then I'm not sure why you would be bothering.
03-23-2017, 06:10 PM | #4 |
Hi mark, you don't replace the head unit, as there is no head unit in the 6th gen, its all smal part of a larger one, all you replace is the HMI unit, and yes its all plug and play, and a new antenna and your done.
03-23-2017, 06:35 PM | #5 |
Sparky
Thanks guys!
Mark |
04-10-2017, 06:30 PM | #6 |
Drives: 2018 Camaro ZL1 Convertible Join Date: Mar 2017
I know where the HMI goes but not the GPS. Can you give me an idea?
04-10-2017, 11:23 PM | #7 |
04-11-2017, 11:25 AM | #8 |
04-11-2017, 07:22 PM | #9 |
If your car came without Nav then there is no stock place, cars that where made with NAV use the same antenna thats on your roof now, but it will cast a lot more for the splitters and cables then you want to spend.
04-02-2021, 09:19 PM | #10 | |
Drives: Chevy Camaro ZL1 Join Date: Oct 2020
Do you know where I can find the splitter and cable and where would I have to mount to splitter? Is it under the glove box? Thank you |
