05-19-2014, 07:34 PM | #1 |
Drives: 2017 Z06 / 2012 CTS Join Date: Jul 2013
Blew a drive belt ...
3.4" pulley on front JRE super tensioner / Napa V25-060947, replaced with Gates belt same length on paper and eye test. This thing does not want to go on. Is there a trick to this, does the tensioner or other pulley need to be adjusted ?
- Sent from phone excuse typos or errors.
SOLD - Maggie Powered 2011 2SS
Procharged Powered 2017 Z06 |
05-19-2014, 08:34 PM | #2 |
Some can be a Bitch to put on. I put it on all pulleys but the blower pulley then put a break over bar on the crank and turn the motor and work the belt on. If that don't work put it on all pulleys but the water pump and work it on. Napa belts are gates belts.
05-19-2014, 08:40 PM | #3 |
Dumb question but you are loosing the tensioner pulley on the blower?
05-19-2014, 09:28 PM | #4 |
Yes sir had it cranked over and it's still a good inch or so shy. I'll have to get another set of hands on it maybe.
05-19-2014, 09:41 PM | #5 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
I loosen the blower idler pulley until it almost comes off, that usually gives enough room to get it on when swing the tensioner over.
05-19-2014, 10:24 PM | #6 |
10.11 @ 136.32
Drives: Black & Yellow 2SS/RS LPE LS7 427 Join Date: Mar 2010
How I do mine.
05-19-2014, 11:12 PM | #7 |
Thanks for the replies and the visual aid ! I'll give that a try tomorrow !!
05-19-2014, 11:14 PM | #8 |
No problem, I'm glad he posted a pic, it's exactly the way I was talking about.
05-20-2014, 11:39 AM | #9 |
Drives: 2010 Camaro 1ss IOM Join Date: May 2009
Yup do the same way on mine as well other wise forget it! It's just to tight!?
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now! |
