01-23-2014, 09:43 AM | #29 |
Drives: 2010 RS/SS Join Date: Dec 2010
Most of our supercharged customers are cammed, my car included. I run our 545 cam with a TVS 2300 @ 10lbs, and make 699rwhp. Mine has maybe 5k on the set up, I don't drive it a whole lot.
We use three bolt COMP cams here. With my supercharged builds I usually do a Katech C5r chain along with Brian Tooley valvetrain, and of course the rest of the supporting parts as well. |
01-23-2014, 10:18 AM | #30 |
Drives: 2017 Z06 / 2012 CTS Join Date: Jul 2013
The shops turning over a high volume of cammed cars, are you running or do you recommend oil(s) with higher ZDDP content / zinc ...
01-26-2014, 08:58 PM | #31 |
Drives: 2013 ZL1 V3RT Join Date: Feb 2012
It makes enough torque and power as it is for sure.. first second and third is worthless if you smash it now...It's just like a bigger cammed car now at lower rpms.. It lopes harder with the blower. Breaking loose at 70mph is enough for me right now... It doesn't help that the temps have been super cold for FL and I'm close to needing new tires though. Hoping that new tires and warmer temps will change the likelihood of spinning if i punch it on the highway.
02-02-2014, 10:11 AM | #32 |
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm Join Date: Feb 2009
yes and yes, but I dis-assembled, inspected and blueprinted it to ensure correct clearances.
URR2SLO - If you're not going fast enough, get out the way......
02-02-2014, 10:41 AM | #33 |
Drives: 2013 Camaro 2ssrs Blue Ray Join Date: Jan 2014
Quick question, would a supercharger without upgraded cam be cause for future engine problems?
02-02-2014, 11:01 AM | #34 | |
WICKDSS
Drives: 2011 1SS/RS IOM LS3 Join Date: May 2010
I have run Redline 10w30 but currently run Valvoline VR1 syn 10w30. I would make sure guys are checking spring pressures or at least changing them out every other season or 20,000 miles. Just my safety net rule of thumb. They're inexpensive considering what damage would cost if you never checked or replace them.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei 11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds. |
02-02-2014, 11:35 AM | #35 |
Drives: 2010 ss Join Date: Dec 2013
408ci 9.5cr...Maggie 3.4 of cog...tps ls3-b blower 3 bolt cam 227/237..4k miles...royal purple oil...PRC heads...600rwhp @10lbs of boost thou a a6
02-02-2014, 01:35 PM | #36 | |
Drives: 2011 Inferno Orange SS Convertible Join Date: Apr 2012
All that said, if you are up to 12psi and still want more power, cam it!
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
02-05-2014, 02:41 AM | #37 |
Drives: 2010 SS 6m, black on black. Join Date: Jul 2010
76mm single turbo. zr1 cam. mobile 1.
Thread Tools | |
