01-16-2014, 03:01 PM | #15 |
Drives: 2011 Inferno Orange SS Convertible Join Date: Apr 2012
Did you put an aftermarket cam and springs in with the stock L99 lifters? If so, what was the lift on the cam and what was your redline set at? I thought you couldn't safely rev the L99 lifters past 6400, and it isn't really worth a cam swap if you aren't going to rev past 6400??
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
01-17-2014, 06:04 AM | #16 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
Who's cammed ?
Custom grind 3 bolt Comp cam, Maggie w/OD cogs and a 3.6" pulley, patriot gold dual coil springs and 63k very "spirited" miles. I've run Mobile 1 since day one except the break in period for the cam and that was royal purple, then back to Mobile 1.
UNDER CONSTRUCTION......again......
01-17-2014, 09:24 AM | #17 | |
How much boost were you seeing and rear wheel numbers are you putting down??
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
01-17-2014, 09:29 PM | #18 |
Drives: 2011 2SS RS 6M Inferno Orange Join Date: Nov 2010
CMS Custom grind Comp Cam ... 3 bolt, 3.5" pulley. Running Amsoil Z-Rod. Cams and lifters like zinc for a barrier between metals. Modern oils don't include it because it's non cat-friendly. If you're cat delete, look for a synthetic oil that has zinc.
The guys who built my motor (Pfaff Engines) run it in all of their marine racing engines and sand rails. They've had a lot of success with it in big hp/hard condition motors. PLUS ... when you drain the oil, you can rub it on your face to avoid sunburn ... or drink it and get rid of a head cold or flu. Zinc ... the all-purpose mineral! |
01-17-2014, 10:49 PM | #19 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
Custom grind 231/248 D .617/596 L 3 bolt
NOT a DD only 4500 mile and close to 200 hard passes oil= Rotella 5W40 and yes its diesel oil BTR Dual valve springs
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
01-17-2014, 11:36 PM | #20 |
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm Join Date: Feb 2009
85k with a Maggie and a 3.2 pulley
79K cammed Mobil1 15w50 Patriot Gold v/s 3 bolt Daily driver
URR2SLO - If you're not going fast enough, get out the way......
01-17-2014, 11:51 PM | #21 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
Hey Rick, you run 15w50? Is that on a stock oil pump?
2010 Camaro SS LS3 - No Modz
01-18-2014, 07:18 AM | #22 |
Drives: 2011 ss camaro Join Date: Jan 2013
Dominator 2X cam from rapid motorsports here. I love my cam! Huge jump in power (70+rwhp with six degrees less total timing), nice idle sound, and may boost leveled out. My TVS use to start around 7.5psi and climb to abt 9.5 at redline...now it stays at 7.5psi all the way to redline.
01-18-2014, 05:33 PM | #23 |
Drives: 2x 05 Vettes/65'AC cobra/68 camaro Join Date: Apr 2009
we haven't had a customer have a issue yet with out Ripper cam, or our stg 2 cam on a FI car. Tires is about all they tear up! lol
ALWAYS GET A 3 BOLT! |
01-19-2014, 08:53 AM | #24 |
Drives: 2013 ZL1 V3RT Join Date: Feb 2012
Tsp 231/236 cam with ecs kit
Been running the cam for 8k and just threw the charger on last month. It's my daily driver. I picked ecs cause since I drive it everyday I didn't want the crazy low end torque. It drives normal at low rpms and hauls after 3000. |
01-19-2014, 09:27 AM | #25 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
That's the second SS Ive seen running the 231/236 and the ECS kit. And both are in Florida lol.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
01-19-2014, 10:26 AM | #26 |
"Black Ace"
Drives: Supercharged 2010 SS, 2016 Golf R Join Date: Aug 2008
Why would you NOT want that crazy low-end torque? To each his own, I guess. My Maggie drives like stock if I'm easy on the throttle. It was even more fun with 4.10 gears (until they broke, haha!) and mine's a daily driver also.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq |
01-19-2014, 10:39 AM | #27 |
Because its easier to hook and easier on the drivetrain.
01-21-2014, 11:15 AM | #28 |
Performance and easy usually do not mix. Violent power properly harnessed equals quickness. With more power comes more wear. There are plenty of smart ways to mitigate potential issues.
