Old 11-24-2020, 12:51 PM   #1
20Bluezl1
Winterizing while working on it
So I have a question this will be my first year I have to winterize a car. I have read how to more or less winterize while not using it. The issue I have is i will be working on the car while its in the garage.
So do I still add something to the gas ?
Also is it a bad idea leaving the car lifted on quickjacks for a long period of time. Planning on doing some suspension work and also headers and exhaust.
Old 11-24-2020, 01:08 PM   #2
Snowwolfe
Drives: CTV5 V Blackwing on order
I stored numerous vehicles from Oct till end of May and I never added anything to the gas. Vehicles were atv’s, sports cars, boats, Motorhomes, etc.
And using Jack stands for a prolonged period won’t hurt anything as long as they were at the proper place.
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 11-24-2020, 01:12 PM   #3
bobfic
bobfic's Avatar
Drives: 2019 ZL1
Adding Stabil wont hurt the fuel system, caution from experience, not to warm up your garage quickly meaning from low temps to mid temps. Lifting the vehicle, I think you'll be fine as long as it's from correct lift points.
bobfic is offline   Reply With Quote
Old 11-24-2020, 01:16 PM   #4
20Bluezl1
I was worried about the suspension being hanging from the car being in the air?
Old 11-24-2020, 01:17 PM   #5
20Bluezl1
What exactly happened when you heated your garage?
Old 11-24-2020, 02:06 PM   #6
bobfic
bobfic's Avatar
Drives: 2019 ZL1
It's when I had 70 Chevelle, temp out side was maybe 25, turn on torpedo heater probably got temp up to 60, I was doing tranny pull for new clutch and throw out bearing, basically everything started sweating, engine, tranny etc. ( dripping wet).
Old 11-24-2020, 02:11 PM   #7
az4783054
Drives: SWXXZL1
I use suggested amounts of TECHRON Concentrate and STA-BIL for winter storage months. It's on a BATTERY TENDER PLUS, covered on a four post lift in a heated shop. I do not overfill the tires but insure they're filled to 30# and check them monthly. I work on it routinely during the winter months to escape wife's 'honey dos'.
"Joe" does a hilarious impression of a slinky toy on stairs.
az4783054 is offline   Reply With Quote
Old 11-24-2020, 08:14 PM   #8
20Bluezl1
What battery tender are guys using?
Old 11-25-2020, 10:15 AM   #9
az4783054
Drives: SWXXZL1
As I posted, it's a BATTERY TENDER PLUS (@1.25AMP), made by DELTRAN.
Old 11-25-2020, 11:38 AM   #10
Mark R
Drives: 2018 ZL-1
I don't think it's such a good idea to let the wheels hang for a long time.
Old 11-25-2020, 03:09 PM   #11
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The reason that a torpedo heater made all the cold surfaces "sweat" was that water vapor is one of the products of combustion of propane (and gasoline), and all that moisture condensed on the cold surfaces.
Old 11-25-2020, 06:37 PM   #12
20Bluezl1
So what is suggested snice I will be doing solid rear cradle bushing and full Spl components on the rear. I was planning on doing little by little
Old 11-25-2020, 08:05 PM   #13
Pupilbone
Pupilbone's Avatar
Drives: 2019 Crush ZL1 M6
Attachment 1050889
Ok - that Chevelle is a thing of beauty
#SaveTheManuals
Pupilbone is offline   Reply With Quote
Old 11-26-2020, 05:44 AM   #14
bobfic
bobfic's Avatar
Drives: 2019 ZL1
Thanks for knowledge.
