Old 11-17-2020, 08:54 AM   #1
RAD18ZL1
Drives: 2018 ZL1
ECM flash
Has anyone ever had a chevrolet dealer re-flash the ECM to get rid of the bog/stutter when leaving a stop light.
RAD18ZL1 is offline   Reply With Quote
Old 11-17-2020, 09:20 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Is there a reflash I missed?...
'20 ZL1 Black "Fury"
Old 11-17-2020, 10:43 AM   #3
SSallday
SSallday's Avatar
Drives: ‘18 ZL1 / ‘22 ZLE
They did this to my car after explaining the bog situation. I’m picking it up today so I’ll let you guys know if there’s any difference
SSallday is offline   Reply With Quote
Old 11-17-2020, 12:08 PM   #4
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
I don't believe there is any ECM update for this. It was explained by Al O in the following thread.
https://www.camaro6.com/forums/showthread.php?t=520373
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is online now   Reply With Quote
Old 11-17-2020, 01:15 PM   #5
RAD18ZL1
Drives: 2018 ZL1
stumble/bog
Ok, heres the question. I don't care about launching from some street or drag strip. Al, the question is when you pull up to a stop sign and just want to take off nice and smooth.I get an stumble as the clutch engages the engine seems to loose power instead of easily taking off. I've even had it die a couple times. There has to be an issue with the ECM or something that is cutting back power instead of slightly increasing the fuel/timing as the car engages. I have tried a different throttle body which made no difference.
Old 11-17-2020, 01:24 PM   #6
RAD18ZL1
Drives: 2018 ZL1
ssallday it would be great to hear how your car does after the you drive it a few miles Maybe you can tell us what they did also. Thanks
Old 11-17-2020, 03:04 PM   #7
SSallday
SSallday's Avatar
I just want to say that my issue is completely related to takeoffs. I don’t launch the car so I’m not worried if it bogs down when dumping the clutch. It was difficult to decide how much gas/clutch to use when taking off. Often, I would give it too much gas because I didn’t want the car to stall. I’m sure that most of you with this issue have done the same thing. After the ECM update, the car is noticeably smoother. I don’t have to use as much gas to get it going and the car doesn’t jump nearly as much when the clutch engages. I can’t say that 100% of the bog is gone. I’m so used to giving it a lot of gas due to the bogging issue so it may take time to adjust. Overall, I don’t have to leave my foot on the clutch as long or give it a ton of gas for takeoffs. I strongly recommend you guys to bring your cars in for this ECM software update
Side note: I had to put my stock air box on for the warranty work so it might improve even more once I put the roto-fab back on the car.
Old 11-17-2020, 04:24 PM   #8
RAD18ZL1
Drives: 2018 ZL1
ssallday you don't happen to know the update bulletin or a Update number connected to it ?
Old 11-17-2020, 05:17 PM   #9
SSallday
SSallday's Avatar
They didn’t put a number on the service sheet. It says “ECM update”
Old 11-17-2020, 06:36 PM   #10
RAD18ZL1
Drives: 2018 ZL1
I see a service update buuletin number on there i will see where that goes.
Russ
Old 11-17-2020, 06:37 PM   #11
CHASLT1
Drives: 2021 Camaro LT1
A after market tune will fix it but the warranty is gone if you do that. A ported TB helps. Or a pedal controller. I find the lag much less on my 2021 LT1 than i did on my 2019 C7.
CHASLT1 is offline   Reply With Quote
Old 11-17-2020, 07:28 PM   #12
Bangkok_ZL1
ZL1 Believer
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Is this issue with a manual Tranny only?
Bangkok_ZL1 is offline   Reply With Quote
Old 11-17-2020, 08:04 PM   #13
SSallday
SSallday's Avatar
Russ
I think that was the recall for the battery cable in the engine bay. They will probably take care of this when you bring your car in
It might be for both but Im not sure. I think most people who have this issue own a manual
Old 11-22-2020, 10:23 PM   #14
Bangkok_ZL1
ZL1 Believer
OK, I will be looking out for this as soon as I start to drive her. Let the countdown begin..... Day 10
