10-14-2020, 01:05 AM | #15 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Refer the sticky above titled PTM modes demystified for all the details and much more Cheers! |
10-14-2020, 06:49 AM | #16 |
Hard to want.
Drives: 2020 red hot 1SS 1LE Join Date: Aug 2017
Great responses gentlemen. I will definitely play with the modes and TC more.
10-14-2020, 07:29 AM | #17 |
Drives: 2023 SS 1LE Join Date: Mar 2020
I don't know if its programmed into the ECM or not, but when I owned my SS 1LE, I did notice once I got the miles over about 5K, the car 'felt' like it was getting more power to the road. Again, maybe it was just my mind playing tricks on me, but it sure felt to me like it was picking up more acceleration and torque. It would easily roast tires if you were too aggressive on the throttle in S mode.
10-14-2020, 08:15 AM | #18 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Could just be the atrocious gearing the M6 has
Smaller wheels/tires will help remedy this alot There are guys on here that claim a 17" drag pack knocks .5 off their quarter mile time. I believe it.
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
10-14-2020, 10:28 AM | #19 | |
Drives: 2SS 1LE Join Date: Oct 2011
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
10-14-2020, 10:32 AM | #20 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
I also had a '15 1SS/1LE and my '19 1SS/1LE is way better in every way. Have plenty of pull in 1st and 2nd.
10-14-2020, 11:14 AM | #21 |
10-17-2020, 08:49 AM | #22 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2015
This is what I do when I drive my car.
2) COMPETITIVE MODE: this turns off TC but keeps StabiliTrak on, while engaging eLSD mode 4. Unlike PTM, this choice gives you access to full power at all times and it is 100% up to you to control it.To ENGAGE THIS MODE: select SPORT via mode button then press TC button TWICE. A dash msg should confirm you're in Comp Mode. Or, you can also select it from TRACK mode by pressing TC button ONLY once. Note no message will be displayed, but the car is now in Competitive Mode. This mode is very handy to access full power by giving up all TC, but retain yaw control nanny (StabiliTrak). This is the same as the old Corvette Comp Mode. |
10-17-2020, 08:55 AM | #23 |
10-17-2020, 08:08 PM | #24 |
Hard to want.
I turned off the nanny’s at the track and the car ran very well. Thanks guys.
10-18-2020, 12:25 AM | #25 |
Drives: like an old lady Join Date: Jun 2012
what did it run? weather?
10-18-2020, 01:58 AM | #26 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
The gearing on this car isn't bad at all TBH. There is only so much you can do with an FR car and you only have 6 gears to work with versus 8 or 10 the autos get. Really, I can't get grip in 1st unless the condition is absolutely optimal.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
10-18-2020, 08:54 AM | #27 |
Hard to want.
Weather wasn’t bad. 80 degrees. The problem was lousy track prep. You really had to slip the clutch to get off the line with out blowing the tires off. Second gear also had wheel spin every run. You could tell the end of season track prep was non existent. Car ran 8.5’s
10-18-2020, 09:32 AM | #28 | |
