11-24-2020, 04:23 PM | #29 |
Nice numbers for easy mods!
Question...how are tunes loaded in the ECU for the ZL1? I am coming from an AMG C63 that was tuned with catless dp's and the tune gets loaded through the OBDII with a handheld device. I had my AMG tuned for pump gas and 100 octane for 1/2 mile racing and I could very easy switch my tunes back and forth with the hand held device. Is it the same type of thing with the ZL1? Thanks.
2018 ZLE - M6, Nightfall Gray
GM previously owned: 2014 SS M6 2014 ZL1 M6 2019 ZL1 M6 2016 Z06 M6 |
11-24-2020, 06:49 PM | #30 |
Tunes are flashed with Hptuners via a laptop computer. EFI live also exists but is the least popular of the two on GM stuff. There is some handheld stuff out there like SCT but imo it's garbage.
2016 NFG 1SS A8
11-24-2020, 11:11 PM | #31 |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
What is the best fuel modification to ensure that the fuel doesn't lean out? Because this fuel delivery system is really foreign to me. Huge fuel pressure and still leaning out. especially if you wanted to run E85 and a decent pulley (nothing huge)?
11-25-2020, 12:57 AM | #32 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Its not, hes judging by that off the HP curve. Up top the stock lt4 blower is kinda shitty. Its all in the tune, there's nothing for you to mod on the fuel system. Anything above 680-700Whp a cam will be needed to make more power which drives the HPFP lobe on the cam (32% is typical). Or you can add meth for higher octane and more power. You cant run E85, its more like E50, and once you start adding more boost E content drops drastically. Leaning out and running out of fuel are 2 different things |
11-25-2020, 08:03 AM | #33 | |
ZL1 Believer
11-25-2020, 08:21 AM | #34 | |
11-25-2020, 08:26 AM | #35 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
11-25-2020, 09:13 AM | #36 | |
2016 NFG 1SS A8
11-25-2020, 09:18 AM | #37 | |
So then I assume my tunes actually stay on the laptop correct? Would the tuner put them on a stick for me to keep? Is that how that works because on my AMG all the tunes were loaded on the hand held device including the stock tune.
04-03-2021, 04:13 AM | #38 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Nice gains. I am also interested in this. My question is whether it is better to change the upper or the lower pulley. Would the gains be the same after tuning? It seems that people prefer to change the lower pulley for some reason.
Also, how easy is it to change the upper pulley? Is it as simple as unscrewing a bolt and then putting on the smaller pulley? I am asking this because I will do it on my own and then I will do a remote tuning given that I am in the UK.
Mosaic black 2018 Camaro 2SS A8 (sold) |
04-03-2021, 04:59 AM | #39 | |
04-03-2021, 06:12 AM | #40 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
04-03-2021, 06:15 AM | #41 | |
04-04-2021, 02:32 AM | #42 |
Drives: '21 ZL1 A10 '08 SRT10 Join Date: Apr 2019
Why is SCT the least preferred method?
2021 ZL1 A10 in Satin Steel Metallic, 2008 Viper Vert M6 in Venom Red, 2018 ZL1 A10 in Bumblebee Yellow (SOLD)
