09-10-2020, 12:04 PM | #15 |
Drives: Camaro ZL1 2019, Jeep GC 5.7 2015 Join Date: Jul 2020
09-10-2020, 12:16 PM | #16 |
Drives: 2018 ZL1 A10 Join Date: May 2019
Great gains....cost-effective gains !
Does going to the smaller 2.3" pulley require a smaller belt to spin it without slipping ? Or can the original belt designed for the original 2.5" pulley be used/retained ? Last edited by DegaZL1; 09-10-2020 at 12:18 PM. Reason: correct typo |
09-10-2020, 12:55 PM | #17 |
Drives: Black 2018 Camaro ZL1 auto Join Date: Nov 2012
No idea if they do remote tuning....
2018 ZL1 A10 with PTB, ROTOFAB, Pulley and tune from
Vengeance. 607 rwhp/647 rwtq |
09-10-2020, 01:25 PM | #18 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
The last time I knew they did remote tuning. Don’t know if that is still true.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
09-10-2020, 05:05 PM | #19 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
09-10-2020, 08:23 PM | #20 |
Drives: 2017 ZL1 Join Date: Apr 2020
Ted j. Told me the pulley swap gains down low but will fall off a bit up top. Plus more heat generated. That is why I am on the fence
2017 ZL1 M6 Silver Ice Metallic
09-10-2020, 09:04 PM | #21 |
Compare the power curves on the dyno graph. power peaks about 500rpm earlier with the pulley. The curve is shifted left. I don't mean anything negative by it, but a larger or even ported supercharger would likely keep making power out further is all.
2016 NFG 1SS A8
09-10-2020, 11:54 PM | #22 |
You don't need a smaller belt. You will use the original.
09-11-2020, 12:12 AM | #23 |
Sarcasm loading --------
is that on 91 or 93 octane fuel?
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
10-13-2020, 12:29 PM | #24 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
10-13-2020, 02:14 PM | #25 |
Drives: 2019 ZL1 Join Date: Mar 2019
Why is Vengeance using STD and not SAE? SAE is the standard, I don't know why places continue to use STD on their dyno sheets so they can inflate numbers.
While your gains on the same dyno from them will be correct, the HP, TORQUE is inflated. There's a reason why car manf's use SAE to rate their engines at the crank, and for a true correct number SAE should be used on the dyno. |
10-14-2020, 08:19 AM | #26 | |
10-14-2020, 08:35 AM | #27 |
10-14-2020, 02:19 PM | #28 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
OP, did your 2.3 pulley and tune require anything else? What was the total cost?
I'm asking because the shop that dynoed my car, which is well known and has a good reputation, recommended their Phase 1 package. It was around $3K, which is more than I want to spend. The package is as follows: Gains up to 60 HP!! ATI Lower Crank Balancer 15% Lower Supercharger Drive Pulley HD RPM Series Drive Belt Roto Fab High Flow Cold Air Intake 160 Degree Thermostat HD Crank Seal Kit ARP Crank Bolt Brisk Performance Spark Plugs Custom Engine (and auto transmission if equipped) Calibration Thanks
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
