Old 10-22-2018, 12:34 PM   #1
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
My best Whipple pass yet
The weather is good this time of year, lots of faster times out there.
New personal best, still on street tires, same setup as last time out when i went 11.40 @ 128!!! Took tires down to 22psi, and instead of leaving off idle, was giving it 2-3k of rpm when leaving. Just waiting for my wheels to come in, already have my DR's and skinnies to put on, hopefully have some time yet to get them on and get to the track.
made 12 passes this day, a bunch of 11.0's, 11,10's, slowed down as the day went on and the track seemed to go away. No lift shifting all day, grabbing 2nd it broke loose spinning a little, sometimes a little wheel hop.
https://youtu.be/VETEBnqSeZ0
2017 1SS M6
Tires used on the pass: Continental Extreme Contact Sport 305/35/20
Performance Mods (if any): Whipple SC, LT4 Fueling, CAI, stock headers, full cat delete, full Borla ATAK, tuned by CSP.
Race Weight: 3975# with 1/2 tank of 93 fuel
Category submitted for: Category #5 M6
R/T.......... .415
60'............. 1.738
330'........... 4.686
660'........... 7.088
660’ mph... 103.28
1000'.......... 9.138
1320'.......... 10.871
1320’ mph… 128.93
Name of the track: Maple Grove Raceway
Date of pass: 10/20/18
Weather conditions: 836 DA.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 10-23-2018, 06:30 AM   #2
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
This is Great , clutch and street tires
Awesome!!!
DapperDan is offline   Reply With Quote
Old 10-23-2018, 11:19 AM   #3
Outahand
Drives: 2018 ZL1
How much boost are you running?
Mark E.
2018 ZL1 NGM A10
87 Grand National. Modified Hot Rod for sale *SOLD*
87 Grand National. Stock
65 Olds Vista Cruiser wagon Grand National motor/tran
66 Bronco Rockbuggy
2006 Dodge 2500 4x4 Cummins 6 speed
Outahand is offline   Reply With Quote
Old 10-23-2018, 11:39 AM   #4
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Great pass, some aren't doing that on drag radial with A8. Good driving also, takes some skills to get where you are with an M6 and 1.73 on street tires makes it more impressive.
Old 10-23-2018, 12:51 PM   #5
Jhunsberger
My P3 gauge with the analog boost read 11.0-11.4 the times I checked it. I dont log my runs.
Old 10-23-2018, 12:52 PM   #6
Jhunsberger
Thank you! Means a lot coming from you!!!
Old 10-23-2018, 01:52 PM   #7
laynlo15
laynlo15's Avatar
I'm an equal opportunity congrats guy no matter what system you run. We all work hard to make sure these cars perform their best. I always appreciate hard work, your doing that. You need to put a hoosier slick on that Camaro and you'll improve those 60' times. So save some bucks and get that done. You could for sure get below or around 10.50 with those. The slicks usually help your mph also since they grow on the big end where a drag radial or street tire stays flat all the way down the track. I run the 28x10-17 Hoosiers on a 17x9.5 race star wheel. Skinnies up front. A few years back I had a NA C5 vet with M6 and launching is an art and I worked very hard like you to get the most out of that car, broke a lot of shit with a drag radial so that's one valuable lesson I learned so I pass that on to the M6 guys so they don't tear shit up
Old 10-23-2018, 02:08 PM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Agreed...I bet it would go 10.4 on a slick. You have to factor the gains from a lighter wheel too. Most running good times are on a drag pack not 20" wheels.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 10-23-2018, 02:12 PM   #9
laynlo15
laynlo15's Avatar
I save 100 lbs over the stock wheels/tires.
Old 10-23-2018, 02:52 PM   #10
Jhunsberger
I have the tires, waiting on wheels to be instock and ship, should be this week. The rear tires are bias plys.
Front
Wheels: Race Star 92's 17x4.50 5x120BC 1.75"BS GLOSS BLACK
Tires: M/T ET FRONT 27.5/4.0-17
Rear
Wheels: Race Star 92's 17x10.5 5x120BC 7" BS GLOSS BLACK
Tires: M/T ET STREET R BIAS 28x11.5-17
I would be pumped with anything better than 10.499. If published weights are true on both my current and incoming setup, I should save 132 lbs total, all rotating mass. I am alittle afraid of breaking axles or driveshaft.....that is next on the list.
Old 11-02-2018, 02:23 PM   #11
BARNESGN
Drives: Sold-G8 GT H/C/I
Fantastic times M6 be proud!
BARNESGN is offline   Reply With Quote
Old 11-11-2018, 09:10 PM   #12
asthmamax11
asthmamax11's Avatar
Your track must be prepped well.
I haven't gotten a single clean run since I've been boosted
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 11-11-2018, 09:20 PM   #13
OneSlowV
OneSlowV's Avatar
Drives: 2018 camaro ss
Very nice congratulations
2019 charger scatpack FBO 11.16@122
2020 CAMARO LT1 6spd 11.02@ 135 dragy approved
OneSlowV is offline   Reply With Quote
Old 11-12-2018, 12:06 PM   #14
Jhunsberger
Got my drag pack on and just trying to find a day/night that works to get to the track.
Using a bathroom scale I weighed both my street and drag setups:
Street
Front: MRR M228 20 x 9 with Continental Extreme Contact Sport 275/35/20 = 56 lbs each
Rear: MRR M228 20 x 11 with Continental Extreme Contact Sport 305/35/20 = 60.5 lbs each
Track
Front: Race Star 92's 17x4.50 with M/T ET FRONT 27.5/4.0-17 = 33 lbs each
Rear: Race Star 92's 17x10.5 with M/T ET STREET R BIAS 28x11.5-17 = 52.5 lbs each.
Savings
Front: 23 lbs each
Rear: 8 lbs each
Total: 62 lbs
I feel like the track setup weighed more than the published weights, I don't know if it is the tires or the wheels.
Also I did have to move the harness in the driver side rear wheel well.
