12-21-2017, 12:47 PM | #15 |
Go to 4:17 of the video. Not normal. It seems like a very low battery. But, I've never seen a low battery be able to crank that long. Usually you'll hear just a bunch of clicks by then.
12-21-2017, 09:40 PM | #16 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
It sounds so sad! Mine has the same problem except it only cranks 2-3 times like that and then turns over.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
12-21-2017, 10:18 PM | #17 |
Drives: 2016 Camaro 1SS Red Hot Join Date: Sep 2015
It is definitely a starter issue. It may be from heat soak or it may be a faulty starter, or it may be a combination of both. Like I had stated in my earlier post it happens on hot days after hard driving. Any other time car starts up almost right away as it should. I don't have any videos but when my starter finally gave up it would make about one to two very slow revolutions of the starter and all interior lights dimmed to almost nothing before the car would go back to ACC mode. The starter was drawing too much amperage. I even let it sit for about 30 min hoping it would cool off enough to restart but then when I tried cranking it again smoke came out from under the hood and you could smell the starter burning up. At that point just had it towed to dealer where starter was replaced and have had no issues since, but I have not driven it hard in hot weather since so I can't totally say if it is fixed. But it was very similar to the slow start in the video, but even slower.
Red Hot 1SS
MRC NPP Black Bow Ties Black Metallic Rally Stripes Black Wheels With Red Outline TPW 12/14/15 1G1FE1R72G0133041 - 12/16 built 2/19/16 - It's mine!! Previous rides: 2011 Camaro LS 2010 Camaro SS 1988 Honda Civic Hatch B18C1 swap |
12-22-2017, 10:41 AM | #18 | |
I assume you will be taking this in again for warranty service. I think you may have a sliding pinion engagement problem. If the gears do not engage smoothly, the flywheel and/or sliding pinion will wear, and this will take time to happen. Assuming you do get a new starter (likely approach by service), I would ask them to examine the sliding pinion for unusual wear patterns. They most likely did not do this last time. Probably just threw out the old starter and were happy when the new one worked. Battery is worth checking, but that would not explain why a brand new starter worked immediately. Heat soak sounds unlikely. Heat soak is typically a solenoid problem and prevents engagement. Sounds like you are getting engagement, then slow cranking. Starter relay contacts can wear, but, again, a new starter would likely have problems right away if the relay contacts were worn. Are you 6 speed or automatic? Clutch drag can be a problem in manual cars (clutch not fully pulling back pressure plate when depressed). |
12-22-2017, 11:14 AM | #19 |
Drives: 2017 2lt rs Join Date: May 2017
There was another post but I can't find it.was something to do with crankshaft main thrust bearing.
12-29-2017, 02:22 PM | #20 |
Drives: Currently Looking for 2019 SS Join Date: Dec 2017
I’m having the same issue on my 2016 ss. Hopefully it’s just the starter. Mine cranks at times and it won’t start at all. Then a burned smell happens right after. They told me that it’s because of my audio sound system I put on. Don’t believe that, I’ve had it for a over a month and now it’s happening.
12-29-2017, 02:25 PM | #21 | |
12-29-2017, 02:48 PM | #22 |
Nothing New started in1967 /////http://camaros.org/forum/index.php?topic=874.0
07-20-2018, 04:42 PM | #23 |
Drives: SS 6 speed of course Join Date: Jan 2016
Don't know about the link and the new thread. I have LTs, so when it started going over 100 in Texas, the starter cranked slowly, now that it is 102 in the shade, about 110 in the lot, my starter is locked up. I will get a new stater and wrap the header tubes near the starter. It is a heat issue no doubt in my mind the stater expands internally and is rubbing against something and when too hot does not spin at all.
OK, I get it, I have LT and this is Texas, but clearly, there is a heat / performance issue with starter, OEM. I going to do a rebuild and probably pull the OEM apart.
07-20-2018, 10:59 PM | #24 |
Drives: MB 1SS Join Date: May 2017
On my second starter as well. Old starter eventually would not start when the car was hot. It would barely turn over. Got stranded twice. New starter fires right up even when hot. Tested it multiple times. It's only been a month so we will see.
07-21-2018, 01:46 AM | #25 |
Drives: 2SS Hyper Blue Join Date: Jun 2018
We've seen this type of thing repeatedly with Rotax motors. Hot temps, high compression and the starter just really has a lot of work cut out for itself when hot. MOAR juice is almost always the solution - but if the starter can't handle the load, meh....square one.
It's interesting as the trend - thank God not on Camaro - is for big SUV's to shut off at stops and restart the instant brake pedal release is detected. This must require some big honkin starter capacity?
2018 Hyper Blue 2SS - SOLD
07-21-2018, 02:43 PM | #26 |
many of the start stop starters on hybrids are build into the bell housing.... FYI.
I dropped mine today and you can smell the burned up smell. I put a blanket on the starter, I put the factory shield back on. I heat wrap thee of the header tubes that were close to the starter. Hopefully this one last 3 years! Will post picks later.
06-05-2019, 09:15 PM | #27 |
Drives: Chevrolet Camaro ss Join Date: May 2019
I have a 16, same issues. Replaced battery and had a load test on battery, starter and alternator...all checked out good. There are days when it starts up quick and then some that are sluggish. Gauge read around 11.5 to sometimes 14.
06-05-2019, 11:47 PM | #28 | ||
Drives: 2017 Super Sport Cam. Join Date: Feb 2018
I've been DD'ing my SS 6 speed for for 2.5 years now. Damn right its a good DD'r. |
Tags |
starter |
