06-21-2021, 01:22 PM | #1 |
Drives: Chevy Camaro LT1, BMW M3 Join Date: Apr 2021
"Normal" Oil Temps during hard driving? - LT1
Hi Guys,
I took my 2021 LT1 A10 up into the SoCal canyons around Malibu for a 'spirited' drive. The car absolutely rips and has more traction than I thought would be possible with the 245 tires and massive power and torque. Great balance and dampening for stock suspension. I know that compared to the SS the model lacks additional cooling, so I'm wondering what oil temps do you guys typically see in a "canyon run" environment - mostly 3rd and 4th gear occasionally down to 2nd. Higher RPMs and heavier throttle but by no means like if I were on a road course. Without much effort temps were in the 240-250 range. Normal temps I find are 190-200. Car was never in limp mode, but is there an issue running the car this hot? I'm used to my 2008 M3 which runs around 210 and tops out around 230 but that car has a smaller engine, heavier oil and more cooling. |
06-21-2021, 01:49 PM | #2 |
Drives: '17 2SS H50 Join Date: Mar 2016
My 2SS never gotten that hot, even when I was pounding on her. I have long tubes and full exhaust without cats.
We see too far.
1100 - 5/26 0000 - Cancelled - 7/5 Contacted Becky - 7/1 2000 - 7/5 3000 - 7/6 3000 - 7/11 TPW 8/1 3100 - 7/18 TPW 8/1 3300 - 7/20 3400 - 7/21 Built - 8/2 - PS 1,182/1 of 699US 4300 - 8/3 5000 - 8/5 6000 - 8/13 |
06-21-2021, 03:42 PM | #3 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
What were the ambient outdoor temps?
A 455 hp V8 generates a lot of heat and having the extra coolers that the SS has (two aux engine coolers, differential cooler, transmission cooler) really makes a big difference. |
06-21-2021, 04:16 PM | #4 |
Drives: 2020 Camaro LT1 Join Date: Feb 2020
I never hit that high in my spirited driving on twisty roads near me in my LT1. My highest during the spirited drives have been in the 210-220 range and I hit 220 only once and it was already near 100 degrees outside.
06-21-2021, 04:39 PM | #5 | |
Not that hot but a lot of the driving was uphill so that may have played a factor. Love this platform but I can see if I was going to be regularly tracking, a SS would be a better choice for the cooling alone. |
06-21-2021, 05:45 PM | #6 |
Did you check your coolant? Maybe it’s low especially in the overflow lower part of the reservoir.
06-21-2021, 05:48 PM | #7 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
240 to 250 F is definitely a bit too high for any driving you can pull off on public roads, I would say. I suspect my 2SS 1LE wouldn't even hit this temperature on the track.
Sent from my MHA-L29 using Tapatalk
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
06-21-2021, 05:58 PM | #8 |
2020 Shadow Gray 2SS
Also try removing the water deflector on the back side of the hood heat extractor, that will open you up for more cooling as well, just put it back on if you drive in the rain or wash the car...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
06-21-2021, 06:04 PM | #9 |
Drives: 2020 LT1 Join Date: Feb 2015
LT1's do have the oil cooler and if it's an A10 the transmission cooler as well.
06-21-2021, 06:36 PM | #10 | |
Drives: 2020 LT1 M6 Join Date: Jan 2016
06-21-2021, 06:48 PM | #11 |
How warm was it when you did the drive? Whether it's coolant or oil, it'll run hotter than normal in the summer. I know in terms of coolant, even my 2007 Cobalt will run over 200° if it's at least 80-90 degrees outside (and the same deal with my dad's C6 so I assume my Camaro would run the same). I'm assuming oil should be running cooler than coolant since you don't want it to thin out and not lubricate. Anyways, before I start spewing off other crap, my point is that if it's hot enough outside, you're gonna have higher than normal temps (even with all the extra cooling). As long as there isn't any smoke coming out of your front end, you'll be fine.
Cars I own/drive:
06-21-2021, 08:24 PM | #12 | |
Will Check if coolant level is low. Car is charging up hill for 3-5 minutes of sustained higher RPM stuff. ambient temps were only in the 70s. Car had no issues but 240+ seems high. Seems like most of you guys are driving in flatter areas so maybe the climbing is the factor pushing up temps.
06-21-2021, 09:01 PM | #13 | |
PKG4U
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
06-22-2021, 12:01 AM | #14 |
Drives: 2021 LT1 A10 RS Join Date: Feb 2021
Thats odd.Mine hasn’t gone over 190 but I’m also still under 1k in break in. And haven’t driven it in anger, or really spirited for that matter.
