09-20-2017, 10:00 AM | #1 |
Drives: 2010 2SS/RS Join Date: Feb 2017
Tire Size Advice Please
So, I just put a set of M228s on my 2010 SS. 20X10 and 20X11. Front tires are 275/30R20 and rears are 295/30R20. I like how the rears look and fit but, the fronts are too low of a profile and, I think, don't look right.
I am thinking of switching the front tires out to 275/35R20. The problem is that the 275/35 is .85" taller than my current rears (295/30). So, will having the fronts showing more sidewall than the rears look bad? Resulting in me having to change the rear size? Uhhhhg... |
09-20-2017, 10:23 AM | #2 |
Instagram: Sangstah
It should be fine, I ran 275/35/20 front, 305/30/20 rear and it didn't look that bad.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
09-20-2017, 02:52 PM | #3 |
Thanks for the reply. The " it didn't look that bad" part is not totally comforting... lol
Not sure which direction to go. |
09-20-2017, 03:05 PM | #4 |
Instagram: Sangstah
those are the tire sizes in my signature photo btw.
09-20-2017, 03:11 PM | #5 |
Drives: 2015 2SS....white Join Date: May 2015
I have 275/35 in front and 315/35 rears and love them. more meaty look for the "muscle car"
2015 Summit White 2SS/RS with NPP.... Roto-Fab intake....Phastek lowering springs....BMR strut brace....custom cut blower cam and tune by Matt Sorian.....@MSTuning...BTR valve train....stainless power longtubes with HF cats....Phastek supplied
09-20-2017, 03:29 PM | #6 |
Drives: 2013 Camaro ZL1 A6 Join Date: May 2013
Those wheel sizes are the the same as the ZL1.
Stock tire size: 285/35/20- front 305/35/20- rear Optional sizes: 275/40/20- front 315/35/20- rear Some even use a 295/35/ 20 front.
SOLD 2013 Camaro ZL1 M6 2013 ZL1 A6- Still completely stock. |
09-20-2017, 08:40 PM | #7 |
Thanks. Those do look good. I am beginning to think that, since my new setup is soooo different than the stock size tires and old wheels, I am just in shock...
Old is the Lexanis |
09-22-2017, 12:49 AM | #8 | |
Drives: 2013 Camaro 2SS/RS Join Date: Apr 2014
U have a huge wheel gap, thats why it looks off. Car needs to be lowered to look better, or do consider changing tire. I Like the 30 profiles on the 6th Gen better. |
09-22-2017, 10:09 AM | #9 | |
Thanks everyone! |
09-29-2017, 01:11 AM | #10 | |
Heres my front tire in 285/35/20 before lowering. next pic is after lowering, i didn’t wanna go too low, don’t want to scrape on driveways. As u can see it doesn’t look much lower than before, but it is. I got coilovers, so I can adjust height on the fly. Hope u got your tires and your happy with them. |
10-03-2017, 04:00 PM | #11 |
Drives: 2015 Camaro 1SS L99 Join Date: Apr 2016
Ive got 20x9.5 fronts and 20x10.5 rears but theyre currently wrapped in my stock 245 and 275 tires lol. Ive been wondering about right tire sizes too since ill be buying new tires soon. My issue more or less is will the meatier tires look good at stock height or will I still need to lower the car about 1-1.25" to get rid of the huge wheel gap?
10-03-2017, 06:34 PM | #12 | |
10-08-2017, 11:03 PM | #13 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
275/40 front and 305/35 rear. Looks sweet.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
10-09-2017, 12:05 AM | #14 |
A 295/30/20 tire is 27" tall
A 275/35/20 tire is 27.6 " tall A 265/35/20 tire is 27.3" tall Why not run a 315/35/20 and a 275/40/20 - they are both 28.7" tall Go to tiresize.com - you can compare all sizes and see what they look like in comparison next to each other before you buy any particular combination
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1000 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod RXT Twin Disc, Vitesse Throttle Controller, 1.5" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
