Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 01-20-2011, 06:13 PM   #29
KIZE
www.gkiser.com
KIZE's Avatar
Drives: 2010 2SS/RS, Auto, Summit White. R
How much do the camaro cast wheels weigh? How much do the lighter forged weigh?
Roto-fab CAI, GMPP exhaust with tips, Pistol Grip shifter with paddle switches, 'Chevrolet' aluminum kick plates, Aluminum Bow Ties, ClearBra front bumper/facia + side views + gills + behind door handles. SS floormats. www.gkiser.com
KIZE www.gkiser.com
KIZE is offline   Reply With Quote
Old 01-21-2011, 07:12 AM   #30
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Stock wheels: http://www.camaro5.com/forums/showthread.php?t=51143
Forged wheels will vary in weight, depending on several things.
-brand name (some focus on performance, others focus on appearance only)
-number of spokes (generally, fewer spokes weigh less)
-lip style (stepped lip weighs less than smooth lip)
-finish choice (chrome weighs the most, polished weighs the least)
Generally, the OEM Camaro wheels are considered heavy. Forged wheels will save quite a bit of rotating mass. I'd ballpark it at 30 lbs or so, total, for a set of four wheels. Just to give you a rough estimate. 30 lbs of rotating mass is quite a bit saved.
Tony
Fquick.com/NineBall
Nine Ball is offline   Reply With Quote
Old 01-21-2011, 10:46 AM   #31
KIZE
www.gkiser.com
KIZE's Avatar
So 30 lbs of rotating mass is more significant than 30 lbs of mass at rest. Due to the energy required to generate the rotation I suppose?
KIZE www.gkiser.com
Old 01-21-2011, 01:13 PM   #32
Nine Ball
Nine Ball's Avatar
Correct. It has to do with physics and the moment of inertia. The heavier the wheels, and the radius at which the weight is carried from the center of spin, all determine how much energy is required to accelerate them. You'll see generalizations tossed around like "X rotating mass saved = X static weight saved". This conversion doesn't exist, as each comparison requires its own calculations. Ballpark used for wheels is often 2:1 or 3:1 ratio. So, 30 lbs off the wheels is similar to removing 60-90 lbs from your vehicle, in terms of acceleration.
Fquick.com/NineBall
Old 01-21-2011, 06:32 PM   #33
KIZE
www.gkiser.com
KIZE's Avatar
Very interesting. Thanks nine ball. Guess I'll have to get some forged at dome point. But the ones I'll want will probably run 3k or so. Have to wait.
KIZE www.gkiser.com
Old 01-24-2011, 09:31 AM   #34
COR Forged
Drives: SS
Send a message via AIM to COR Forged
Check this out guys; a little more explanation.
http://www.corwheels.com/forged-vs-c...he-difference/
COR Forged is offline   Reply With Quote
Old 03-07-2011, 04:22 PM   #35
hv92
Drives: .
So the Savini "mono di forza" rims are one piece rims then right?im confused. :(
My name is Jake Huntsey. New YORK NEW YORK!
hv92 is offline   Reply With Quote
Old 03-08-2011, 08:32 AM   #36
Nine Ball
Nine Ball's Avatar
Savini Mono di Forza are indeed 1-piece forged monoblock wheels.
Fquick.com/NineBall
Old 08-15-2011, 12:40 PM   #37
bomberro71
Drives: 2010 camaro ss
I want to get 22" savini's for my 2010 camaro ss. I called the dealership about the rim size that I want to do and they said they would not recommend it because it will mess with the suspension. I noticed that many of you have 22"s and higher on your car and would like to know your opinions.
bomberro71 is offline   Reply With Quote
Old 01-31-2012, 01:27 PM   #38
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
what brand does PQ have?
-John S.
grocerygetter is offline   Reply With Quote
Old 01-31-2012, 07:09 PM   #39
Nine Ball
Nine Ball's Avatar
PQ = Savini 3-piece forged construction.
Fquick.com/NineBall
Old 01-31-2012, 08:27 PM   #40
toehead93
Drives: 2014 2SS/1LE
You just made this post to be the first guy with 2 sticky threads. Come on....admit it.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 03-11-2012, 04:17 PM   #41
One-Bad-ZL1
So easy to love Camaros
One-Bad-ZL1's Avatar
Drives: 2013 ZL1 VR #3457
Send a message via Yahoo to One-Bad-ZL1
Hey wheel experts, are the stock 20's polished aluminum sprayed with a clear coat? I'm seeing what looks like delamination on the backside of the rim. When GM mounted the tire, is it possible they are damaging this coating at the outer edge of the rim and it starts migrating inward? Woundering what can be done before it gets worse. Think this is considered a warrantee issue?
One-Bad-ZL1 is offline   Reply With Quote
Old 08-18-2014, 02:30 PM   #42
BadazzTA02
Drives: 2002 Kandy Copper Trans Am WS6
I have a set of HRE 547's 18x9.5's & 18x10.5's on my 02 WS6. I was involved in an accident and my front driver side wheel was damaged. I work at a Performance/Wheel and tire shop and called my distributors to find out how much a replacement wheel would cost. My cost for an 18x9.5 was more than most of the other 20" multi-piece wheels I've sold. When i asked my distributor why this was the case, he told me that HRE and other higher end wheel companies use European hoops/barrels vs Japanese hoops/barrels. Is this true and are their any major differences between European hoops and Japanese hoops? I ended up contacting HRE and got a price from them to fix and refinish the wheel which was less than having to buy a new one. Not only was the turn-around time extremely fast, they even took over 30% off the original price I was quoted.
BadazzTA02 is offline   Reply With Quote
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 05:00 PM
NEW MODEL: 22X9,22X10.5 WL26 WHEEL TIRE PACKAGES! GREAT PRICES!! BestWheelDeals Wheels / Tires 27 09-14-2010 07:05 AM
2010 Camaro Wheel Locks Caution... willie2323 Wheels and Tires Talk Sponsored by The Tire Rack 3 06-20-2010 09:41 AM
So what is the difference between wheel construction types?? Mindz Wheels and Tires Talk Sponsored by The Tire Rack 3 12-21-2009 06:42 PM
