Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 09-22-2010, 10:31 AM   #15
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
Rudy:
What is the average life expectancy on a set of Scorpions or Blizzaks? I had 4 new Blizzaks on my wifes car a few years ago. After 7,000 miles (less than 2 seasons, they were swapped out in spring and fall) the 4 were shot....just normal easy driving with the car in alignment.
My 2010 Camaro is a DD, and I put about 16k a year on it. In the above scenerio, I won't get even one full winter season out of the winter tires. I assume the more aggressive winter tire tread heats up more and wears out quicker? Still, if I can only get 7k-8k out of a set of winter tires, it makes it almost unaffordable even with your great prices.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 09-22-2010, 10:46 AM   #16
Don57
Drives a beast!
Don57's Avatar
Drives: Yellow 2014 Camaro 2SS/RS
Originally Posted by 67 Convertible View Post
Rudy:
After 7,000 miles (less than 2 seasons...
if I can only get 7k-8k out of a set...
You're posting in both miles and kilometers. Which is it?
Don57 is offline   Reply With Quote
Old 09-22-2010, 10:50 AM   #17
67 Convertible
7k = 7 thousand
8k = 8 thousand
k=thousand.....k is abreviation for thousand not kilometer
I believe the abbreviation for kilometer is KM
Both postings are in miles.
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
Old 09-22-2010, 11:11 AM   #18
Don57
Drives a beast!
Don57's Avatar
7k = 7 thousand
8k = 8 thousand
I'm a little stupid this morning.
Old 09-22-2010, 11:17 AM   #19
ndcamaro
Drives: Camaor 2ss
Originally Posted by cab2g View Post
In your opinion, which tire is better for deep snow/slush? The Blizzak or Scorpion. I plan on mounting one of these two on my stock 20" wheels next month
I am planning to purchase the Blizzak or Scorpions as well (Blizzak LM-60 245 45 20) My main question is will these tires fit the wider wheels in the rear? Right now the summer tires are 275 40 20. My plan is to mount the winter tires on the stock rims for the winter and then pick up new wheels in the spring for my Pzero summers.
Just nervous about putting the narrower tire in the rear on the stock rims.
ndcamaro is offline   Reply With Quote
Old 09-22-2010, 12:16 PM   #20
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
Rudy:
I would try the Pirelli as they are know for better tread life. 7k-8k seems very low. I am not sure what happened there. You should get 30k or maybe more with the Pirellis.
Rudy@Tirerack is offline   Reply With Quote
Old 09-22-2010, 12:17 PM   #21
Rudy@Tirerack
Yest the 245/45R20 will fti without issue. Nothing to be nervous about. Actually by replacing the wider rear tire it will help improve snow performance.
Old 09-22-2010, 03:18 PM   #22
Rudy@Tirerack
I would do the Sciorpion ICE and Snow!
Old 09-23-2010, 06:16 AM   #23
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
Rudy, I plan to put Continental Extreme Contacts DWS on my SS this fall. They were recomended here on camaro5 and by a local tire dealer. I don't use my car in the snow, but found it almost undrivable last winter below 40 degrees. How do these compare to other brands on the Camaro SS ?
myold88 is offline   Reply With Quote
Old 09-23-2010, 07:21 AM   #24
Rudy@Tirerack
^ The Conti Extreme Contact DWS is one of the better all season tires. You will loose some dry traction in the summer months but they should work fine down to about 20 degrees. So yeah 30-40 degrees you should have much better driveability for sure.
Old 09-23-2010, 08:37 AM   #25
fcu678
5Th Gen (Craig)
fcu678's Avatar
Drives: 2014 C7
Rudy,
I'm not trying to jack the thread but do you have a rim and tire combo to use as a spare on an SS and fit in the spare tire location in the trunk?? Mine is an early build with the weights on the calipers.
Thanks,
Craig
2014 C7
fcu678 is offline   Reply With Quote
Old 09-23-2010, 08:54 AM   #26
Chaotic73
BUMBLLB
Chaotic73's Avatar
Drives: 2010 Camaro 1LT/RS
I'm having Yokohama Parada Spec-X installed on mine this weekend. Got a good price $775 installed 245/45/20 fronts & 275/40/20 rears.
Chaotic73 is offline   Reply With Quote
Old 09-23-2010, 11:49 AM   #27
Rudy@Tirerack
Originally Posted by fcu678 View Post
Rudy,
Thanks,
Craig
We should be able to figure something out. Give me a call.
Thank you very much.
Old 09-23-2010, 05:29 PM   #28
Cyber/Orange10
Cyber/orange10
Cyber/Orange10's Avatar
Drives: 2010 2SS 96 CE LT4, 12 CRUZE ECO
Send a message via AIM to Cyber/Orange10
Hey Rudy, Let us all know about the spare tire, alot would be interested.....
picking up my Scorpion Ice and Snows tomorrow, ready for winter!
Cyber/Orange10 is offline   Reply With Quote
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
Winter Tires for my 2010 Camaro in Canada Camarodriver Canada 21 12-20-2010 11:19 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
