TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 11-11-2010, 07:58 PM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Changing colors in you LED's for your ABL
So this is for info only, How to Changing colors in you ABL LED's, There are lots of LED out there in all kind of Size's and colors, The one's i will post pics of are the ones that come in your door or if you have done the dash ABL.
If you google you can find lots of 5 mm LED and there are many colors, so lets get to it.
In one pic you see new LED's and then the next pic is the back of the led holder from gm there are 4 tabs that hold the housing on use a small pic and small flat tip screw driver to open it then there is a pic of the inside there is only a 1/4 watt resister and the led all you do is mach the resister to the led your using.
Change out the OEM led and snap the housing back, and your done have fun.
2SSRS@Gen5diy is offline   Reply With Quote
Old 11-11-2010, 09:42 PM   #2
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
ur my hero. more power to the mod monsters.
lupe
overhaulengines is offline   Reply With Quote
Old 11-11-2010, 10:45 PM   #3
camaro2lt
camaro2lt's Avatar
Drives: 2010 Camaro 2LT VR/RS CGM Rally's
how do you get to the abl in the door panel?
camaro2lt is offline   Reply With Quote
Old 11-11-2010, 10:49 PM   #4
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
Thanks for the DIY man i will be doing this at some point.. i only know of 3 leds i can change, the door panels and one for the auto shifter bezel are there any other ones like behind the gauges?
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Old 11-11-2010, 11:14 PM   #5
camaro2lt
camaro2lt's Avatar
how do you change the auto shifter ones ?
Old 11-11-2010, 11:18 PM   #6
mbrusco103
mbrusco103's Avatar
i removed the whole trim piece and switched it with a boot for now but when i did there was one of those leds lighting up the PRNDM
Old 11-11-2010, 11:57 PM   #7
camaro2lt
camaro2lt's Avatar
interesting.............
Old 11-12-2010, 06:07 AM   #8
2SSRS@Gen5diy
You need to remove the door panels of the car,
http://www.camaro5.com/forums/showpo...9&postcount=29
http://www.camaro5.com/forums/showpo...0&postcount=30
No that is it the one's behind the gauges are a lot more work, Here is a pic from a old thread that rharon started.
Old 11-12-2010, 07:29 AM   #9
mbrusco103
mbrusco103's Avatar
okay thanks! I definitely don't want to mess with those
Old 11-12-2010, 07:38 AM   #10
2SSRS@Gen5diy
But you can do it, its only more work.( and a good soldering iron. LOL)
Old 11-12-2010, 08:11 AM   #11
Noturday
[Not-your-day]
Noturday's Avatar
Drives: 2005 Avalanche
pretty cool, who would have thought it would be as simple as one 5mm led. i would put some heat shrink over those solder joints, just for good measure
Noturday is offline   Reply With Quote
Old 11-12-2010, 08:33 AM   #12
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
So on a 1-PITA, getting these door panels off?
Click to view my build thread
The Stig is offline   Reply With Quote
Old 11-12-2010, 08:36 AM   #13
2SSRS@Gen5diy
That was the way GM did it there is a divider in the housing so the two can not touch, It works good no need to mod.
First time you do it 3-PITA after that its a 1-PITA, You need to remember that all the parts on the car snap on and off so pull the panel off after you remove ALL the screws.
Old 11-12-2010, 09:05 AM   #14
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
for all those that dont want to mess with resistors and leds, aac sells pre wired leds so if you have aac lighting bulbs in your car already you can use these to match those colors as well, if you have any questions about it you can pm me and ill try to help you out with it too
camaro4mybday is offline   Reply With Quote
How to Wire Footwell Lighting TonyNo Camaro DIY & HOW-TO instructions & discussions 804 09-05-2021 08:13 AM
Colors on Camaro you like...vs colors you hate...and a vote for ugliest color..hehe chevydude26 5th Gen Camaro SS LS LT General Discussions 15 05-26-2010 09:00 PM
DIY: ABL Color Change Tecca Camaro DIY & HOW-TO instructions & discussions 20 05-18-2010 06:50 PM
hmm I think I am changing colors again TaylorRyanSS 5th Gen Camaro SS LS LT General Discussions 19 05-21-2009 10:21 PM
Coolest new car colors KILLER74Z28 General Automotive + Other Cars Discussion 8 04-12-2007 08:24 AM
