![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Tackling those reluctant mods
I have wanting to do this mod for some time and decided it was time to do some research and get it done. The mod involves taking off the engine support braces, the ones attached to the firewall and the shock towers, not the one across the engine. Painting them a different color than reinstall.
Decided I wanted to keep the oringinals black, as I keep all original parts. Went on e-bay and found several listed. Upon receiving these I painted them with some some left over paint I had for a caliper project. I used VHT high temp primer, color and clear paint knowing these might be subject to some high temps near the exhaust manifolds. Now the install is the harder part. There have been previous threads on just how do you get these braces off. They don't come off by just taking off the bolts that hold them. The trick is the cowl plenum #9 has to come off. Once you take off the wipers the plastic cowl is next by removing all the push pins (I call them that). You then remove the cover over the cabin air filter. You then find all the 10 mm bolts and nuts that must come off to raise the cowl plenum. The center one is a bitch to get off so I just loosened it enough to raise the plenum ends to clear the center mount on the braces. But, now you must contend with the glue type gasket under the plenum to the firewall. I was able to pry the plenum off enough on each end to make the clearance I needed. You don't need to completely remove the plenum. Reinstall is just the steps in reverse. Some pics to visualize the project. Sorry about the pics upside down, still can't figure out why this happens
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
Looks good. So did you just spray over the old black paint on the ones you ordered? Or did you strip the black paint?
Sent from my moto g(7) power using Tapatalk
I scuffed the surface before putting on the primer.
Thanks.
Thread Tools | |
